So, I'm going to post the SMART output for each of my drives below... Some of the values I'm confused on are weird looking values, such as Seek_Error_Rate and Raw_Read_Error_Rate... they seem super high, but don't seem to trip any errors/etc. Also, I have 8 uncorrectable sectors on one of the drives and I get notifications of this error whenever I reboot the system. I've read tons of threads on it, but am still confused on what to do to get rid of the errors and have the drive re-allocate the 8 sectors. If this number kept going up, I'd replace the drive, but since its stayed at 8, it seems fair to say that the drive is 99% ok, correct?
Thanks for any help... the outputs are below...
I also have had a problem with one drive getting "removed" which I have other posts about... I recently swapped the cables from ada3/ada4 to see if the problem follows the drive (ada3 in this printout) or the port... hopefully that was the best method to figure out if the drive or the controller is causing the problem...
ada0
ada1
ada0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda Green (AF)
Device Model: ST2000DL003-9VT166
Firmware Version: CC32
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Feb 3 11:17:39 2014 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 623) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 344) minutes.
Conveyance self-test routine
SCT capabilities: (0x30b7) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 108 099 006 Pre-fail Always - 20713464
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 38
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 065 060 030 Pre-fail Always - 42984189700
9 Power_On_Hours 0x0032 086 086 000 Old_age Always - 12292
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 20
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 065 052 045 Old_age Always - 35 (Min/Max 15/35)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 39
194 Temperature_Celsius 0x0022 035 048 000 Old_age Always - 35 (0 15 0 0 0)
195 Hardware_ECC_Recovered 0x001a 019 005 000 Old_age Always - 20713464
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 8
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 8
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 117093693402992
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2061743694
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2856705717
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: read failure 90% 12283 3907019896
# 2 Short offline Completed: read failure 90% 12271 3907019896
# 3 Short offline Completed: read failure 90% 12253 3907019896
# 4 Short offline Completed: read failure 90% 12241 3907019896
# 5 Short offline Completed: read failure 90% 12229 3907019896
# 6 Short offline Completed: read failure 90% 12217 3907019896
# 7 Short offline Completed: read failure 90% 12205 3907019896
# 8 Short offline Completed: read failure 90% 12193 3907019896
# 9 Short offline Completed: read failure 90% 12181 3907019896
#10 Short offline Completed: read failure 90% 12169 3907019896
#11 Extended offline Completed: read failure 90% 12163 3907019896
#12 Short offline Completed: read failure 90% 12157 3907019896
#13 Short offline Completed: read failure 90% 12145 3907019896
#14 Short offline Completed: read failure 90% 12133 3907019896
#15 Short offline Completed: read failure 90% 12121 3907019896
#16 Short offline Completed: read failure 90% 12109 3907019896
#17 Short offline Completed: read failure 90% 12097 3907019896
#18 Short offline Completed: read failure 90% 12085 3907019896
#19 Short offline Completed: read failure 90% 12071 3907019896
#20 Short offline Completed: read failure 90% 12059 3907019896
#21 Short offline Completed: read failure 90% 12047 3907019896
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada1
Local Time is: Mon Feb 3 11:18:21 2014 CST
been run.
data collection: ( 612) seconds.
command.
power-saving mode.
recommended polling time: ( 330) minutes.
1 Raw_Read_Error_Rate 0x000f 107 099 006 Pre-fail Always - 13371376
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 18
7 Seek_Error_Rate 0x000f 067 060 030 Pre-fail Always - 25804307431
9 Power_On_Hours 0x0032 087 087 000 Old_age Always - 11558
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 18
190 Airflow_Temperature_Cel 0x0022 068 055 045 Old_age Always - 32 (Min/Max 15/32)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 12
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 18
194 Temperature_Celsius 0x0022 032 045 000 Old_age Always - 32 (0 15 0 0 0)
195 Hardware_ECC_Recovered 0x001a 013 003 000 Old_age Always - 13371376
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 97641786518822
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3154412256
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 4106603239
No Errors Logged
# 1 Short offline Completed without error 00% 11549 -
# 2 Short offline Completed without error 00% 11537 -
# 3 Short offline Completed without error 00% 11519 -
# 4 Short offline Completed without error 00% 11507 -
# 5 Short offline Completed without error 00% 11495 -
# 6 Short offline Completed without error 00% 11483 -
# 7 Short offline Completed without error 00% 11471 -
# 8 Short offline Completed without error 00% 11459 -
# 9 Short offline Completed without error 00% 11447 -
#10 Short offline Completed without error 00% 11435 -
#11 Extended offline Completed without error 00% 11429 -
#12 Short offline Completed without error 00% 11423 -
#13 Short offline Completed without error 00% 11411 -
#14 Short offline Completed without error 00% 11399 -
#15 Short offline Completed without error 00% 11387 -
#16 Short offline Completed without error 00% 11375 -
#17 Short offline Completed without error 00% 11363 -
#18 Short offline Completed without error 00% 11351 -
#19 Short offline Completed without error 00% 11337 -
#20 Short offline Completed without error 00% 11325 -
#21 Short offline Completed without error 00% 11313 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
