JayG30
 - Jun 26, 2013
I have a freenas box running an older version (9.1). The USB drive it is on is a bit old and I'd like to change it. I'd also like to upgrade to the most recent version. I know how to install the latest version on the new USB stick. And I'd assume I also want to export my configuration to import into the new USB stick, correct? Also, do I have to detach my volume before changing the USB stick with the upgraded freenas version on it and then import it?
This is what I was thinking the steps I'd have to follow would be, but not sure.
Yes? No?
Thanks.
- Detach volume
 - Shut the machine down
 - Change the USB sticks
 - Boot back up into the new freenas
 - Auto Import volume
 - Import configuration
Yes? No?
Thanks.
