Cristian Barbuscia
- Nov 16, 2015
searched a little bit but didn't find anything similar to my situation.
I'm in the need of both upgrading my hardware (from a HP Proliant to a Fujitsu Celsius Desktop) and changing my vdev configuration (3 disks Raidz to 4 disks Raidz)
I learned that once the vdev is created you cannot change his (her?) configuration and you can only add a different vdev to the pool. So, as in my case both the Proliant and the Celsius have only four 3.5" slots, I can add one more disk but without any fault tolerance.
I also learned that changing the hardware is somehow 'easy', saving the configuration from GUI, and importing it inside the new installation after switching the disks between the two.
So, I'm wondering if there's a path fitting my needs like, for example, saving the data (in this casa what data exactly, I guess not only the shares and the plugins ?!?) outside the freenas, create the new installation with the 4 disks raidz vdev and import the saved data in it.
Ok, I guess that's all.
Thanks to anyone who can help me in advance
P.S.
In case you'll ask: My first configuration with 3 disks was based on both testing and hardware availability at the moment.
P.S.
