Is it possible to open shell in 132x50 by default (rather than 80x25)?
G gearhead Contributor Joined Mar 6, 2013 Messages 137 May 1, 2015 #1 Is it possible to open shell in 132x50 by default (rather than 80x25)?
Ericloewe Server Wrangler Moderator Joined Feb 15, 2014 Messages 20,194 May 1, 2015 #2 No, but you can completely avoid that issue by using SSH.
danb35 Hall of Famer Joined Aug 16, 2011 Messages 15,504 May 1, 2015 #3 That issue, and many others (like mishandling of control characters).
Ericloewe Server Wrangler Moderator Joined Feb 15, 2014 Messages 20,194 May 1, 2015 #4 danb35 said: That issue, and many others (like mishandling of control characters). Click to expand... Avoids bad behavior on any less-than-perfect network Easier copy-and-paste Allows for public key authentication I'm sure I missed many more
D dlavigne Guest May 1, 2015 #6 Would be a good feature request for 10, assuming it keeps webshell. If you make one, post the issue number here.
anodos Sambassador iXsystems Joined Mar 6, 2014 Messages 9,553 May 2, 2015 #7 Ericloewe said: Avoids bad behavior on any less-than-perfect network Easier copy-and-paste Allows for public key authentication I'm sure I missed many more Click to expand... Can use comic sans font.
Ericloewe Server Wrangler Moderator Joined Feb 15, 2014 Messages 20,194 May 3, 2015 #8 anodos said: Can use comic sans font. Click to expand... CLI without a fixed-width font? That's crazy! /missing the point
