Jailer
Not strong, but bad
- Sep 12, 2014
I've been having a problem getting certbot to run from a script to handle renewals that I've been using for a couple years that has ran without issue in the past. Seems something broke in the latest package version of py27-certbot so I uninstalled it and installed py37-certbot. When I run the command in the script from the terminal it runs fine without error. When trying to run the exact same command from my script via a cron task set in the GUI it's seems to still be trying to run py27-certbot which isn't installed and of course returns an error. This is run from a jail I have set up to handle my nginx reverse proxy. Nginx, openssl111 and certbot (and it's dependencies) are all that's installed in this jail.
The error:
The script:
The only thing I've been able to find online remotely similar is this thread on the FreeBSD forums but trying the things listed there didn't help.
I don't know what to do to fix this. The simlink seems fine so I don't know what is triggering certbot to try to use the older version. How do I go about debugging this? The letsencrypt error log isn't much help.
The error:
/usr/local/bin/certbot-2.7: Command not found. Command: csh /renew.sh failed!
The script:
#!/bin/sh /usr/local/bin/certbot renew --post-hook "service nginx restart" --quiet
