hi, i am trying to get my freenas working as a cd ripper / burner.
so far i have been using abcde successfully to rip from the cd drive but writing fails with what i think are permission problems. can someone help?
in the jail i have the following situation:
less /etc/devfs.conf
own cd0 root:operator
perm cd0 0660
own xpt0 root:operator
perm xpt0 0660
own pass4 root:operator
perm pass4 0660
sudo camcontrol devlist
<PIONEER BD-RW BDR-UD03 1.10> at scbus8 target 0 lun 0 (pass4,cd0)
ls -l /dev/{cd0,xpt0,pass4}
crw-r----- 1 root operator 0x88 Dec 19 21:51 /dev/cd0
crw------- 1 root operator 0x43 Dec 5 20:11 /dev/pass4
crw------- 1 root operator 0x38 Dec 5 20:11 /dev/xpt0
this is surprising to me as i would think i gave the operator group rw permissions? i can't do 'camcontrol devlist' as my user which is a member of the operator group, which seems logical but is not desired.
then, the actual problem:
i try 'cdrecord dev=8,0,0 -checkdrive' which gives 'insufficient privileges' type errors.
then, 'sudo cdrecord dev=8,0,0 -checkdrive' gives
Cdrecord-ProDVD-ProBD-Clone 3.01 (amd64-unknown-freebsd11.3) Copyright (C) 1995-2015 Joerg Schilling
scsidev: '8,0,0'
scsibus: 8 target: 0 lun: 0
cdrecord: Operation not permitted. Cannot open or use SCSI driver.
what's wrong? can i just chmod the device files? that seems wonky...
thanks for any help!
perm cd0 0660
perm xpt0 0660
perm pass4 0660
scsidev: '8,0,0'
