Can't see volume after motherboard change
screeny
Hi All,
I have issue after mother board change.
I see the disks but can't see the volumes :( Can anyone help me?
This is what I see:
gpsguy
Active Member
Please read the forum rules (in red at the top of the page) and provide detailed system specs as well as the version of FreeNAS that you are using.
screeny
This is the system.
Mar 29 22:58:10 freenas newsyslog[1671]: logfile first created
Mar 29 22:58:10 freenas syslogd: kernel boot file is /boot/kernel/kernel
Mar 29 22:58:10 freenas kernel: Copyright (c) 1992-2013 The FreeBSD Project.
Mar 29 22:58:10 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Mar 29 22:58:10 freenas kernel: The Regents of the University of California. All rights reserved.
Mar 29 22:58:10 freenas kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Mar 29 22:58:10 freenas kernel: FreeBSD 9.1-STABLE #0 r+16f6355: Tue Aug 27 00:38:40 PDT 2013
Mar 29 22:58:10 freenas kernel: root@build.ixsystems.com:/tank/home/jkh/src/freenas/os-base/amd64/tank/home/jkh/src/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
Mar 29 22:58:10 freenas kernel: gcc version 4.2.1 20070831 patched [FreeBSD]
Mar 29 22:58:10 freenas kernel: CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 5600+ (2800.06-MHz K8-class CPU)
Mar 29 22:58:10 freenas kernel: Origin = "AuthenticAMD" Id = 0x40f33 Family = 0xf Model = 0x43 Stepping = 3
Mar 29 22:58:10 freenas kernel: Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Mar 29 22:58:10 freenas kernel: Features2=0x2001<SSE3,CX16>
Mar 29 22:58:10 freenas kernel: AMD Features=0xea500800<SYSCALL,NX,MMX+,FFXSR,RDTSCP,LM,3DNow!+,3DNow!>
Mar 29 22:58:10 freenas kernel: AMD Features2=0x1f<LAHF,CMP,SVM,ExtAPIC,CR8>
Mar 29 22:58:10 freenas kernel: real memory = 3221225472 (3072 MB)
Mar 29 22:58:10 freenas kernel: avail memory = 3081035776 (2938 MB)
Mar 29 22:58:10 freenas kernel: Event timer "LAPIC" quality 400
Mar 29 22:58:10 freenas kernel: ACPI APIC Table: <MSIISM OEMAPIC >
Mar 29 22:58:10 freenas kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Mar 29 22:58:10 freenas kernel: FreeBSD/SMP: 1 package(s) x 2 core(s)
Mar 29 22:58:10 freenas kernel: cpu0 (BSP): APIC ID: 0
Mar 29 22:58:10 freenas kernel: cpu1 (AP): APIC ID: 1
Mar 29 22:58:10 freenas kernel: WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Mar 29 22:58:10 freenas kernel: ioapic0 <Version 1.1> irqs 0-23 on motherboard
Mar 29 22:58:10 freenas kernel: kbd1 at kbdmux0
Mar 29 22:58:10 freenas kernel: aesni0: No AESNI support.
Mar 29 22:58:10 freenas kernel: cryptosoft0: <software crypto> on motherboard
Mar 29 22:58:10 freenas kernel: acpi0: <MSIISM OEMRSDT> on motherboard
Mar 29 22:58:10 freenas kernel: acpi0: Power Button (fixed)
Mar 29 22:58:10 freenas kernel: acpi0: reservation of fec00000, 1000 (3) failed
Mar 29 22:58:10 freenas kernel: acpi0: reservation of fee00000, 1000 (3) failed
Mar 29 22:58:10 freenas kernel: acpi0: reservation of 0, a0000 (3) failed
Mar 29 22:58:10 freenas kernel: acpi0: reservation of 100000, bff00000 (3) failed
Mar 29 22:58:10 freenas kernel: cpu0: <ACPI CPU> on acpi0
Mar 29 22:58:10 freenas kernel: cpu1: <ACPI CPU> on acpi0
Mar 29 22:58:10 freenas kernel: attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Mar 29 22:58:10 freenas kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Mar 29 22:58:10 freenas kernel: Event timer "i8254" frequency 1193182 Hz quality 100
Mar 29 22:58:10 freenas kernel: atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Mar 29 22:58:10 freenas kernel: Event timer "RTC" frequency 32768 Hz quality 0
Mar 29 22:58:10 freenas kernel: hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed00fff on acpi0
Mar 29 22:58:10 freenas kernel: Timecounter "HPET" frequency 25000000 Hz quality 950
Mar 29 22:58:10 freenas kernel: Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
Mar 29 22:58:10 freenas kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x2008-0x200b on acpi0
Mar 29 22:58:10 freenas kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Mar 29 22:58:10 freenas kernel: pci0: <ACPI PCI bus> on pcib0
Mar 29 22:58:10 freenas kernel: pci0: <memory, RAM> at device 0.0 (no driver attached)
Mar 29 22:58:10 freenas kernel: isab0: <PCI-ISA bridge> port 0x2f00-0x2f7f at device 1.0 on pci0
Mar 29 22:58:10 freenas kernel: isa0: <ISA bus> on isab0
Mar 29 22:58:10 freenas kernel: pci0: <serial bus, SMBus> at device 1.1 (no driver attached)
Mar 29 22:58:10 freenas kernel: ohci0: <nVidia nForce MCP55 USB Controller> mem 0xfeafb000-0xfeafbfff irq 22 at device 2.0 on pci0
Mar 29 22:58:10 freenas kernel: usbus0 on ohci0
Mar 29 22:58:10 freenas kernel: ehci0: <NVIDIA nForce MCP55 USB 2.0 controller> mem 0xfeafac00-0xfeafacff irq 23 at device 2.1 on pci0
Mar 29 22:58:10 freenas kernel: usbus1: EHCI version 1.0
Mar 29 22:58:10 freenas kernel: usbus1 on ehci0
Mar 29 22:58:10 freenas kernel: atapci0: <nVidia nForce MCP55 SATA300 controller> port 0xd480-0xd487,0xd400-0xd403,0xd080-0xd087,0xd000-0xd003,0xcc00-0xcc0f mem 0xfeaf9000-0xfeaf9fff irq 21 at device 5.0 on pci0
Mar 29 22:58:10 freenas kernel: ata2: <ATA channel> at channel 0 on atapci0
Mar 29 22:58:10 freenas kernel: ata3: <ATA channel> at channel 1 on atapci0
Mar 29 22:58:10 freenas kernel: atapci1: <nVidia nForce MCP55 SATA300 controller> port 0xc880-0xc887,0xc800-0xc803,0xc480-0xc487,0xc400-0xc403,0xc080-0xc08f mem 0xfeaf8000-0xfeaf8fff irq 22 at device 5.1 on pci0
Mar 29 22:58:10 freenas kernel: ata4: <ATA channel> at channel 0 on atapci1
Mar 29 22:58:10 freenas kernel: ata5: <ATA channel> at channel 1 on atapci1
Mar 29 22:58:10 freenas kernel: atapci2: <nVidia nForce MCP55 SATA300 controller> port 0xc000-0xc007,0xbc00-0xbc03,0xb880-0xb887,0xb800-0xb803,0xb480-0xb48f mem 0xfeaf7000-0xfeaf7fff irq 23 at device 5.2 on pci0
Mar 29 22:58:10 freenas kernel: ata6: <ATA channel> at channel 0 on atapci2
Mar 29 22:58:10 freenas kernel: ata7: <ATA channel> at channel 1 on atapci2
Mar 29 22:58:10 freenas kernel: pcib1: <ACPI PCI-PCI bridge> at device 6.0 on pci0
Mar 29 22:58:10 freenas kernel: pci1: <ACPI PCI bus> on pcib1
Mar 29 22:58:10 freenas kernel: pci0: <multimedia, HDA> at device 6.1 (no driver attached)
Mar 29 22:58:10 freenas kernel: nfe0: <NVIDIA nForce MCP55 Networking Adapter> port 0xb400-0xb407 mem 0xfeaf6000-0xfeaf6fff,0xfeafa800-0xfeafa8ff,0xfeafa400-0xfeafa40f irq 20 at device 8.0 on pci0
Mar 29 22:58:10 freenas kernel: miibus0: <MII bus> on nfe0
Mar 29 22:58:10 freenas kernel: ciphy0: <Vitesse VSC8601 10/100/1000TX PHY> PHY 0 on miibus0
Mar 29 22:58:10 freenas kernel: ciphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Mar 29 22:58:10 freenas kernel: nfe0: Ethernet address: 00:16:17:ba:21:72
Mar 29 22:58:10 freenas kernel: nfe1: <NVIDIA nForce MCP55 Networking Adapter> port 0xb080-0xb087 mem 0xfeaf5000-0xfeaf5fff,0xfeafa000-0xfeafa0ff,0xfeaf4c00-0xfeaf4c0f irq 20 at device 9.0 on pci0
Mar 29 22:58:10 freenas kernel: miibus1: <MII bus> on nfe1
Mar 29 22:58:10 freenas kernel: ciphy1: <Vitesse VSC8601 10/100/1000TX PHY> PHY 1 on miibus1
Mar 29 22:58:10 freenas kernel: ciphy1: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Mar 29 22:58:10 freenas kernel: nfe1: Ethernet address: 00:16:17:ba:18:ae
Mar 29 22:58:10 freenas kernel: pcib2: <ACPI PCI-PCI bridge> at device 10.0 on pci0
Mar 29 22:58:10 freenas kernel: pci2: <ACPI PCI bus> on pcib2
Mar 29 22:58:10 freenas kernel: pcib3: <ACPI PCI-PCI bridge> at device 11.0 on pci0
Mar 29 22:58:10 freenas kernel: pci3: <ACPI PCI bus> on pcib3
Mar 29 22:58:10 freenas kernel: pcib4: <ACPI PCI-PCI bridge> at device 12.0 on pci0
Mar 29 22:58:10 freenas kernel: pci4: <ACPI PCI bus> on pcib4
Mar 29 22:58:10 freenas kernel: pcib5: <ACPI PCI-PCI bridge> at device 13.0 on pci0
Mar 29 22:58:10 freenas kernel: pci5: <ACPI PCI bus> on pcib5
Mar 29 22:58:10 freenas kernel: pcib6: <ACPI PCI-PCI bridge> at device 14.0 on pci0
Mar 29 22:58:10 freenas kernel: pci6: <ACPI PCI bus> on pcib6
Mar 29 22:58:10 freenas kernel: pcib7: <ACPI PCI-PCI bridge> at device 15.0 on pci0
Mar 29 22:58:10 freenas kernel: pci7: <ACPI PCI bus> on pcib7
Mar 29 22:58:10 freenas kernel: vgapci0: <VGA-compatible display> port 0xe000-0xe0ff mem 0xf0000000-0xf7ffffff,0xfebf0000-0xfebfffff irq 16 at device 0.0 on pci7
Mar 29 22:58:10 freenas kernel: vgapci1: <VGA-compatible display> mem 0xfebe0000-0xfebeffff at device 0.1 on pci7
Mar 29 22:58:10 freenas kernel: amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb3
Mar 29 22:58:10 freenas kernel: acpi_button0: <Power Button> on acpi0
Mar 29 22:58:10 freenas kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Mar 29 22:58:10 freenas kernel: atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Mar 29 22:58:10 freenas kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Mar 29 22:58:10 freenas kernel: kbd0 at atkbd0
Mar 29 22:58:10 freenas kernel: atkbd0: [GIANT-LOCKED]
Mar 29 22:58:10 freenas kernel: orm0: <ISA Option ROM> at iomem 0xc0000-0xccfff on isa0
Mar 29 22:58:10 freenas kernel: sc0: <System console> at flags 0x100 on isa0
Mar 29 22:58:10 freenas kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Mar 29 22:58:10 freenas kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Mar 29 22:58:10 freenas kernel: ppc0: cannot reserve I/O port range
Mar 29 22:58:10 freenas kernel: powernow0: <PowerNow! K8> on cpu0
Mar 29 22:58:10 freenas kernel: powernow1: <PowerNow! K8> on cpu1
Mar 29 22:58:10 freenas kernel: Timecounters tick every 1.000 msec
Mar 29 22:58:10 freenas kernel: ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Mar 29 22:58:10 freenas kernel: DUMMYNET 0xfffffe00025e7600 with IPv6 initialized (100409)
Mar 29 22:58:10 freenas kernel: load_dn_sched dn_sched WF2Q+ loaded
Mar 29 22:58:10 freenas kernel: load_dn_sched dn_sched FIFO loaded
Mar 29 22:58:10 freenas kernel: load_dn_sched dn_sched PRIO loaded
Mar 29 22:58:10 freenas kernel: load_dn_sched dn_sched QFQ loaded
Mar 29 22:58:10 freenas kernel: load_dn_sched dn_sched RR loaded
Mar 29 22:58:10 freenas kernel: usbus0: 12Mbps Full Speed USB v1.0
Mar 29 22:58:10 freenas kernel: usbus1: 480Mbps High Speed USB v2.0
Mar 29 22:58:10 freenas kernel: ugen0.1: <nVidia> at usbus0
Mar 29 22:58:10 freenas kernel: uhub0: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
Mar 29 22:58:10 freenas kernel: ugen1.1: <nVidia> at usbus1
Mar 29 22:58:10 freenas kernel: uhub1: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Mar 29 22:58:10 freenas kernel: uhub0: 10 ports with 10 removable, self powered
Mar 29 22:58:10 freenas kernel: ada0 at ata2 bus 0 scbus0 target 0 lun 0
Mar 29 22:58:10 freenas kernel: ada0: <WDC WD30EZRX-00D8PB0 80.00A80> ATA-9 SATA 3.x device
Mar 29 22:58:10 freenas kernel: ada0: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
Mar 29 22:58:10 freenas kernel: ada0: 2861587MB (5860531055 512 byte sectors: 16H 63S/T 16383C)
Mar 29 22:58:10 freenas kernel: ada0: quirks=0x1<4K>
Mar 29 22:58:10 freenas kernel: ada0: Previously was known as ad4
Mar 29 22:58:10 freenas kernel: SMP: AP CPU #1 Launched!
Mar 29 22:58:10 freenas kernel: uhub1: 10 ports with 10 removable, self powered
Mar 29 22:58:10 freenas kernel: Root mount waiting for: usbus1
Mar 29 22:58:10 freenas kernel: ugen1.2: <Kingston> at usbus1
Mar 29 22:58:10 freenas kernel: umass0: <Kingston DataTraveler G3, class 0/0, rev 2.00/1.00, addr 2> on usbus1
Mar 29 22:58:10 freenas kernel: da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
Mar 29 22:58:10 freenas kernel: da0: <Kingston DataTraveler G3 PMAP> Removable Direct Access SCSI-0 device
Mar 29 22:58:10 freenas kernel: da0: 40.000MB/s transfers
Mar 29 22:58:10 freenas kernel: da0: 30568MB (62603264 512 byte sectors: 255H 63S/T 3896C)
Mar 29 22:58:10 freenas kernel: da0: quirks=0x2<NO_6_BYTE>
Mar 29 22:58:10 freenas kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
Mar 29 22:58:10 freenas kernel: ugen0.2: <Unknown> at usbus0 (disconnected)
Mar 29 22:58:10 freenas kernel: ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
Mar 29 22:58:10 freenas kernel: to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Mar 29 22:58:10 freenas kernel: ZFS filesystem version: 5
Mar 29 22:58:10 freenas kernel: ZFS storage pool version: features support (5000)
Mar 29 22:58:10 freenas kernel: GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)
Mar 29 22:58:10 freenas kernel: GEOM_ELI: Device ada0p1.eli created.
Mar 29 22:58:10 freenas kernel: GEOM_ELI: Encryption: AES-XTS 256
Mar 29 22:58:10 freenas kernel: GEOM_ELI: Crypto: software
Mar 29 22:58:11 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Mar 29 22:58:11 freenas ntpd[1868]: ntpd 4.2.4p5-a (1)
Mar 29 22:58:11 freenas kernel: ....+++
Mar 29 22:58:13 freenas proftpd[2088]: 127.0.0.1 - ProFTPD 1.3.4c (maint) (built Tue Aug 27 2013 07:56:15 UTC) standalone mode STARTUP
Mar 29 22:58:18 freenas ntpd[1869]: time reset -0.193918 s
Mar 29 22:58:19 freenas avahi-daemon[2446]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Mar 29 22:58:22 freenas root: /etc/rc: WARNING: failed to start mediatomb
Mar 29 22:58:41 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Mar 29 22:59:19 freenas last message repeated 3 times
SweetAndLow
Sweet'NASty
Please post just specifics of you want help no one is going to read your poorly formatted pasted log.
nForce chipset? And you're surprised that stuff isn't working?
You're going to have to tell us what the old motherboard was and what the new one is. Even then, I get feeling all we'll be able to say is "well, then don't do that!".
screeny
Do you think if I upgrade with clear new 9.3 FreeNAS I should import the volumes?
Thank you!
screeny
Can anyone help me please? I'M in a big trouble. I'm willing to pay for online help... just please help me... thank you!
gpsguy
Active Member
As SweetAndLow said, please post the specifics on your hardware. See some of the examples in the users signature files. Post that in the body of your message - those of us on mobile devices can't see signatures.
I tried scrolling through your file 4 times on my phone and the RAM figure didn't leap out at me. I did see where caching is disabled - so it's less than 4 GB.
Are you using 32 or 64 bit FreeNAS. What's the version number for FreeNAS?
The minimum RAM requirement for ZFS on FreeNAS is 8GB. At best you have less than 1/2 the RAM. Did you have more RAM in your old system?
Sent from my phone
screeny
Sent from my phone
Now it's 3GB only because I want to save my data and I'll upgrade later on. I'm using 64bit. Today I installef 9.3 with clear install. Right now the most important to save my data. Can you help me via skype of Teamviewer? Just give a price please. We're photography professionals and the work stucke for last two days because of this :( Thank you!
screeny
FreeNAS-9-3 x64
3GB DDR2 RAM
MSI K9N
AMD 5600+ Ghz
2x 3TB WD Green
1x 2TB WD
1x 750Gb Samsung
gpsguy
Active Member
With just 3GB of RAM, I wouldn't have upgraded it to 9.3. Hopefully you didn't upgrade your pool too.
At this point, you really need to find a way to put 8GB in it. Or, another machine that already has at least 8GB.
Since this is business critical, you might want to call iXsystems and pay them for support.
You are welcome to try iXsystems (support.ixsystems.com). But you aren't going to get too far if you don't even meet the minimum requirements. They know better than to try to use a system that doesn't have at least 8GB of RAM. :P
screeny
Okay. Thank you for info.
I moved everything to a mainstream 8core 8GB ram machine. I imported 1 volume but not see the content.
Nothing new :(
I read something about an application on bsd which restore the zpool to the original and after there's the possibility to give new volume name.
Is it something real?
Bidule0hm
Server Electronics Sorcerer
The problem is, if the volume has been damaged because too little RAM it'll still be damaged and won't import if you add more RAM or even change the whole system. I don't say it's that but it's a possibility.
gpsguy
Active Member
As BiduleOhm said, your pool might have been damaged when you had too little RAM.
That being said, after you imported your volume, did you reconfigure your sharing, etc. You never said whether you restored a configuration backup, or started from a blank state.
screeny
Unfortunatelly I lost :( I don't know where I am or what should I do... so this is the end... thank you all for your input!
ser_rhaegar
