Can't see my volume datasets on web gui
madmax
I can no longer see my data sets after the attempted importing of 4 TB NTFS USB hard drive. My data can be access through SSH and CIFS so the data sets are intact but don't show up in the GUI under the tab Storage -> Volumes . The disk are there in View Disks. I have remove the USB drive from the computer, restarted and refresh the screen and no luck. I am running 9.3 Beta 11/18. See attached picture.
Side note: If this thread is going to be remove/move could you kindly leave a message for OP so there are aware of there mistake. Thanks.
D
dlavigne
Guest
Will it let you import your volume? If not, what is the output of zpool status (in code tags)?
madmax
The volume import doesn't show any of the drives to import. I have access to data through CIFS and SSH. There is a pool there. Just doesn't show up in the GUI anymore. I don't have the tree of data sets and icons for the options for each data set within the GUI.
@FreeNAS ~]$ zpool status
  pool: Tank
state: ONLINE
  scan: none requested
        NAME                                                STATE     READ WRITE CKSUM
        Tank                                                ONLINE       0     0     0
          raidz2-0                                          ONLINE       0     0     0
            gptid/96b57a3b-6f61-11e4-99f1-40167e372277.eli  ONLINE       0     0     0
            gptid/975b8594-6f61-11e4-99f1-40167e372277.eli  ONLINE       0     0     0
            gptid/97fec6ba-6f61-11e4-99f1-40167e372277.eli  ONLINE       0     0     0
            gptid/98a31df6-6f61-11e4-99f1-40167e372277.eli  ONLINE       0     0     0
            gptid/994d720e-6f61-11e4-99f1-40167e372277.eli  ONLINE       0     0     0
            gptid/99fdf9a9-6f61-11e4-99f1-40167e372277.eli  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h13m with 0 errors on Tue Nov 18 21:07:02 2014
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
madmax
Yes its encrypted. I don't' know how much help I can be because I just reinstalled and I haven't had the problem nor I have tried mount a USB drive.
