From disabling a drive in the boot menu in the BIOS to manually selecting the drive I want to boot from with the boot selector from the BIOS to even swapping the drives between SATA ports, I can't ever boot from the specific drive I want.
So I have 3 hard drives.
Drive A
Drive B
Drive C
I had installed FN on A just as a quick experiment to see and play around with FN, but I had no plans to keep it as a boot drive since it is a 1TB drive. I then decided I want to use B for the boot and installed FN on it. Problem is, the system always wants to boot from A. Even if I select B from the boot menu, the box ends up booting up from A. I know B is bootable into FN because I physically disconnected A, and the system boots right up into B. C just sits in there looking pretty and always being recognized by FN regardless of either booting up from A or B.
So technically, I have 2 drives with FN installed on them. Even manually selecting to boot from B, why does the box always choose to boot from A when I know B boots up into FN when A is physically disconnected? I know it sounds like a weird BIOS issue of perhaps it is deciding it prefers to boot from A for whatever reason.
Drive A
Drive B
Drive C
