Can't delete jail dataset
axg20202
I have a jail that was deleted but the dataset remains and can't be deleted. Within the GUI, I get the following error when I try to delete it:
"cannot destroy 'main_volume/jails/plex': filesystem has dependent clones use '-R' to destroy the following datasets: main_volume/jails/.warden-template-standard-11.0-x64"
Can someone help a complete noob fix this? Not sure how to apply the -R command. Have tried to destroy the dataset at the command line by SSH with no joy.
scrappy
Do you have any storage attached to the jail? If so, delete it and try again.
axg20202
Unfortunately not. The jail is deleted so no longer listed in jails, and no jail storage is listed for it either. However, the dataset for the jail is still listed as a volume. Can’t delete it.
D
dlavigne
Guest
That is what is preventing it. You'll need to figure out which snapshot or clone is still referring to it.
Devilstompa
I'm having the same problem with the jail not deleting. I did delete it from storage tho
Mr_N
I've never used jails and have a jails dataset, is it possible its a default thing?
