bazzacad
- May 1, 2019
I just upgraded from v12 to v13.0-U3.1.
After doing so, I can no longer delete files from one of my SMB shares, the other shares seem to be fine.
When I delete the file in Windows Explorer, it just shows up again after doing a refresh.
Here are the permisions:
If I view the log.smbd file after trying to delete a file, I get these errors:
I'm also getting an alert about the smb.core file being created. If I delete it, it just comes back again.
Here is the output of testparm -s:
[2023/01/10 10:24:21.625234, 0] ../../lib/util/fault.c:176(smb_panic_log)
INTERNAL ERROR: Mountpath is incorrect in pid 83835 (4.15.11)
[2023/01/10 10:24:21.625244, 0] ../../lib/util/fault.c:181(smb_panic_log)
If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.sam
ba.org/index.php/Bug_Reporting
[2023/01/10 10:24:21.625285, 0] ../../lib/util/fault.c:182(smb_panic_log)
[2023/01/10 10:24:21.625294, 0] ../../lib/util/fault.c:184(smb_panic_log)
PANIC (pid 83835): Mountpath is incorrect in 4.15.11
[2023/01/10 10:24:21.626584, 0] ../../lib/util/fault.c:288(log_stack_trace)
BACKTRACE: 25 stack frames:
#0 0x8014ab8c7 <log_stack_trace+0x37> at /usr/local/lib/samba4/libsamba-util.so.0
#1 0x8014ab9a1 <smb_panic+0x11> at /usr/local/lib/samba4/libsamba-util.so.0
#2 0x8162c85db <samba_init_module+0x29cb> at /usr/local/lib/shared-modules/vfs/recycle.so
#3 0x8162c625d <samba_init_module+0x64d> at /usr/local/lib/shared-modules/vfs/recycle.so
#4 0x801aeb2b6 <close_file+0x1fa6> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so
#5 0x801ae9449 <close_file+0x139> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so
#6 0x801b23dc8 <smbd_smb2_request_process_close+0x828> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so
#7 0x801b237ea <smbd_smb2_request_process_close+0x24a> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so
#8 0x801b15edc <smbd_smb2_request_dispatch+0x17ec> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so
#9 0x801b1a622 <smbd_smb2_process_negprot+0x24f2> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so
#10 0x80277c5cd <tevent_common_invoke_fd_handler+0x9d> at /usr/local/lib/samba4/private/libtevent.so.0
#11 0x8027829ad <tevent_ctx_get_iocb+0x73d> at /usr/local/lib/samba4/private/libtevent.so.0
#12 0x802781220 <tevent_signal_get_tag+0x230> at /usr/local/lib/samba4/private/libtevent.so.0
#13 0x80277b5e1 <_tevent_loop_once+0xe1> at /usr/local/lib/samba4/private/libtevent.so.0
#14 0x80277b842 <tevent_common_loop_wait+0x32> at /usr/local/lib/samba4/private/libtevent.so.0
#15 0x8027812a0 <tevent_signal_get_tag+0x2b0> at /usr/local/lib/samba4/private/libtevent.so.0
#16 0x801b038e3 <smbd_process+0x7b3> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so
#17 0x1032373 <main+0x44b3> at /usr/local/sbin/smbd
#18 0x80277c5cd <tevent_common_invoke_fd_handler+0x9d> at /usr/local/lib/samba4/private/libtevent.so.0
#19 0x8027829ad <tevent_ctx_get_iocb+0x73d> at /usr/local/lib/samba4/private/libtevent.so.0
#20 0x802781220 <tevent_signal_get_tag+0x230> at /usr/local/lib/samba4/private/libtevent.so.0
#21 0x80277b5e1 <_tevent_loop_once+0xe1> at /usr/local/lib/samba4/private/libtevent.so.0
#22 0x80277b842 <tevent_common_loop_wait+0x32> at /usr/local/lib/samba4/private/libtevent.so.0
#23 0x8027812a0 <tevent_signal_get_tag+0x2b0> at /usr/local/lib/samba4/private/libtevent.so.0
#24 0x10308df <main+0x2a1f> at /usr/local/sbin/smbd
[2023/01/10 10:24:21.626767, 0] ../../source3/lib/dumpcore.c:315(dump_core)
dumping core in /var/db/system/cores
[2023/01/10 10:24:21.639459, 1] ../../source3/librpc/crypto/gse_krb5.c:418(fill_mem_keytab_from_system_keytab)
../../source3/librpc/crypto/gse_krb5.c:417: krb5_kt_start_seq_get failed (No such file or directory)
[2023/01/10 10:24:21.641107, 1] ../../source3/librpc/crypto/gse_krb5.c:418(fill_mem_keytab_from_system_keytab)
[2023/01/10 10:24:22.644998, 1] ../../source3/librpc/crypto/gse_krb5.c:418(fill_mem_keytab_from_system_keytab)
root@gecko[/var/log/samba4]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_DOMAIN_MEMBER
# Global parameters
[global]
aio max threads = 2
bind interfaces only = Yes
client ldap sasl wrapping = seal
deadtime = 3
disable spoolss = Yes
dns proxy = No
domain master = No
enable web service discovery = Yes
kerberos method = secrets and keytab
kernel change notify = No
load printers = No
local master = No
logging = file
max log size = 5120
min domain uid = 500
obey pam restrictions = Yes
preferred master = No
realm = TIPPING.LAN
registry shares = Yes
restrict anonymous = 2
security = ADS
server multi channel support = No
server role = member server
server string = FreeNAS Server Gecko
template homedir = /mnt/share/homes/%D/%U
template shell = /bin/sh
unix extensions = No
winbind cache time = 7200
winbind enum groups = Yes
winbind enum users = Yes
winbind max domain connections = 10
winbind nss info = rfc2307
workgroup = STA
recycle:minsize = 20
recycle:maxsize = 50000000
recycle:exclude = *.tmp, .~lock*, *.autosave, *.pdf~
recycle:subdir_mode = 0770
recycle:directory_mode = 0770
idmap config *: range = 70001-100000
idmap config sta: schema_mode = rfc2307
idmap config sta: range = 500-70000
idmap config sta: backend = ad
rpc_server:mdssvc = disabled
rpc_daemon:mdssd = disabled
idmap config * : backend = tdb
create mask = 0770
directory mask = 0770
directory name cache size = 0
dos filemode = Yes
wide links = Yes
[assoc]
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/assoc
read only = No
smbd max xattr size = 2097152
store dos attributes = No
vfs objects = zfs_space zfsacl streams_xattr recycle
recycle:subdir_mode = 0700
recycle:directory_mode = 0777
recycle:touch = yes
recycle:versions = yes
recycle:keeptree = yes
recycle:repository = .recycle/%D/%U
nfs4:chown = true
[drawings]
comment = AutoCAD Drawing Storage
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/Drawings
read only = No
recycle:exclude_dir = *_backup
recycle:exclude = *.tmp, *~lock*, *.dwl, *.dwl2, *.bak, *.pdf~, acad.dce, *Thumbs.db, *qlm.lck
recycle:touch = yes
nfs4:chown = true
[admin]
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/admin
read only = No
recycle:touch = yes
nfs4:chown = true
[tipping]
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/tipping
read only = No
recycle:touch = yes
nfs4:chown = true
[images]
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/images
read only = No
nfs4:chown = true
[projDocs]
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/projDocs
read only = No
nfs4:chown = true
[Office]
comment = Office Shared Files
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/Office
read only = No
recycle:exclude = *.tmp, *Thumbs.db, *~lock*, *.pdf~
recycle:touch = yes
nfs4:chown = true
[engindata]
comment = Engineering Project files
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/engindata
read only = No
recycle:exclude = *.tmp, *~lock*, *.autosave, *.pdf~, acad.dce, *.dwl, *.dwl2, *.bak, *.bak2, *Thumbs.db
recycle:touch = yes
nfs4:chown = true
[TmpShare]
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/TmpShare
read only = No
nfs4:chown = true
[homes]
admin users = "@STA\domain admins"
ea support = No
hide dot files = No
level2 oplocks = No
map archive = No
oplocks = No
path = /mnt/share/homes/%D/%U
read only = No
nfs4:chown = true
[profiles]
ea support = No
hide dot files = No
map archive = No
path = /mnt/share/profiles
read only = No
nfs4:chown = true
