Can't create Volume with disks attached to LSI 9300-8e
Matt Kent
seeing /dev/mfi and /dev/pass devices.
Drives can be presented as individual "JBOD" via a HW RAID controller and some think that they aren't using HW RAID, when they actually are. In this case though, the LSI does look like it's in IT mode, but I'm not sure about the H730.
I think there is an issue with the driver and H730 controller combo. And either a physical issue between the LSI and the MD1400, or an incompatibility with the MD1400.
For testing I have now removed the H730 form the machine, and put 4 of the drives form the server in the MD1400 shelf. The remaining drive are disconnected from the server as well.
Are you saying that there may be a problem with the LSI talking to the MD1400 at this point? Would you suggest manual partition and volume creation on the drives to see if they are addressable by the base OS?
Matt
depasseg
FreeNAS Replicant
It's possible that there is a compatibility issue with the LSI, MD1400 and FreeBSD. What's the output of camcontrol devlist -v?
Matt Kent
Here you go:
scbus0 on ahcich0 bus 0:
<>                                 at scbus0 target -1 lun ffffffff ()
scbus1 on ahcich1 bus 0:
<>                                 at scbus1 target -1 lun ffffffff ()
scbus2 on ahcich8 bus 0:
<>                                 at scbus2 target -1 lun ffffffff ()
scbus3 on ahcich9 bus 0:
<>                                 at scbus3 target -1 lun ffffffff ()
scbus4 on mpr0 bus 0:
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 8 lun 0 (pass0,da0)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 9 lun 0 (pass1,da1)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 10 lun 0 (pass2,da2)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 11 lun 0 (pass3,da3)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 12 lun 0 (pass4,da4)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 13 lun 0 (pass5,da5)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 14 lun 0 (pass6,da6)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 15 lun 0 (pass7,da7)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 16 lun 0 (pass8,da8)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 17 lun 0 (pass9,da9)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 18 lun 0 (pass10,da10)
<TOSHIBA MG04SCA40EN DS06>         at scbus4 target 19 lun 0 (pass11,da11)
<DELL MD1400 1.05>                 at scbus4 target 20 lun 0 (pass12,ses0)
<>                                 at scbus4 target -1 lun ffffffff ()
scbus5 on camsim0 bus 0:
<>                                 at scbus5 target -1 lun ffffffff ()
scbus6 on umass-sim0 bus 0:
<SanDisk Ultra 1.00>               at scbus6 target 0 lun 0 (pass13,da12)
scbus-1 on xpt0 bus 0:
<>                                 at scbus-1 target -1 lun ffffffff (xpt0)
Matt
depasseg
FreeNAS Replicant
That looks good. Can you use the GUI to create a 12 disk vdev (or 2 6's) as a test?
Matt Kent
I'm assuming that you mean use the web GUI, click on "Volume Manager" and create a volume? If so, then that is the issue that brought me here in the first place.
This is in the messages log:
manage.py: [middleware.exceptions:37] [MiddlewareError: Unable to GPT format the disk "da0"] Along with a whole host of ILLEGAL REQUEST messages from the driver. I can post them but they are essentially the same as the ones that I have posted before.
Matt
depasseg
FreeNAS Replicant
Hmm. Can you trying wiping those disks? The simplest and fastest way I know is to use gpart destroy -F da0 (through da11). And then confirm the partitions are all clear with gpart show.
Let's try to figure out this MD1400 issue and then move to the H730 and IT mode issue.
Matt Kent
Done:
[root@xxxxxxxx] ~# gpart destroy -F da0
da0 destroyed
[root@xxxxxxxx] ~# gpart destroy -F da1
gpart: arg0 'da1': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da2
gpart: arg0 'da2': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da3
gpart: arg0 'da3': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da4
gpart: arg0 'da4': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da5
gpart: arg0 'da5': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da6
gpart: arg0 'da6': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da7
gpart: arg0 'da7': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da9
gpart: arg0 'da9': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da8
gpart: arg0 'da8': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da10
gpart: arg0 'da10': Invalid argument
[root@xxxxxxxx] ~# gpart destroy -F da11
gpart: arg0 'da11': Invalid argument
[root@xxxxxxxx] ~# gpart show
=>      34  30463933  da12  GPT  (15G)
        34      1024     1  bios-boot  (512K)
      1058         6        - free -  (3.0K)
      1064  30462896     2  freebsd-zfs  (15G)
  30463960         7        - free -  (3.5K)
Next?
depasseg
FreeNAS Replicant
My bad, try /dev/da0 I didn't feel like testing that command on my drives. :smile:
depasseg
FreeNAS Replicant
That could be the case. Maybe try to create a partition manually to see if it's possible (as you guessed a couple hours ago). :smile:
Spearfoot
He of the long foot
I think the invalid argument is due to the drives not having any partitions set. The gpart show is at the bottom of my last message.
I may be wrong, but I'm pretty sure you need to run the command with the full device spec: /dev/da0 etc. We can't see the 'gpart show' results for any devices except da12.
EDIT: I'm wrong; you don't need to specify the /dev/ prefix with the gpart command. Carry on... :oops:
Matt Kent
And here is my results:
[root@xxxxxxxx] ~# gpart create -s GPT /dev/da3
gpart: Invalid argument
[root@xxxxxxxx] ~# tail -6 /var/log/messages
Aug 23 13:48:52 xxxxxxxx (da2:mpr0:0:10:0): Error 22, Unretryable error
Aug 23 13:49:10 xxxxxxxx (da3:mpr0:0:11:0): WRITE(16). CDB: 8a 00 00 00 00 01 d1 c0 be 8f 00 00 00 20 00 00
Aug 23 13:49:10 xxxxxxxx (da3:mpr0:0:11:0): CAM status: SCSI Status Error
Aug 23 13:49:10 xxxxxxxx (da3:mpr0:0:11:0): SCSI status: Check Condition
Aug 23 13:49:10 xxxxxxxx (da3:mpr0:0:11:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code)
Aug 23 13:49:10 xxxxxxxx (da3:mpr0:0:11:0): Error 22, Unretryable error
=>        34  7814037101  da0  GPT  (3.6T)
          34  7814037101       - free -  (3.6T)
=>        34  7814037101  da1  GPT  (3.6T)
=>        34  7814037101  da2  GPT  (3.6T)
=>        34  7814037101  da3  GPT  (3.6T)
I'm hoping that I have a simple error in my command syntax? Please? ^_^
Spearfoot
He of the long foot
I'm really starting to believe you simply have a bad card...
depasseg
FreeNAS Replicant
Matt Kent
Same response.
[root@xxxxxxxx] ~# gpart create -s GPT da4
Aug 23 14:01:17 xxxxxxxx (da4:mpr0:0:12:0): WRITE(16). CDB: 8a 00 00 00 00 01 d1 c0 be 8f 00 00 00 20 00 00
Aug 23 14:01:17 xxxxxxxx (da4:mpr0:0:12:0): CAM status: SCSI Status Error
Aug 23 14:01:17 xxxxxxxx (da4:mpr0:0:12:0): SCSI status: Check Condition
Aug 23 14:01:17 xxxxxxxx (da4:mpr0:0:12:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code)
Aug 23 14:01:17 xxxxxxxx (da4:mpr0:0:12:0): Error 22, Unretryable error
=>        34  7814037101  da4  GPT  (3.6T)
Manufacturer tech support there I come.
bstaudt
I understand this is an old thread but I ran into a similar situation with similar hardware and was able to solve it by formatting my drives with the following command and rebooting FreeNAS. After that I was able to create volumes using webUI:
sg_format --format --fmtpinfo=0 /dev/daX
Other forum threads about this issue:
https://forums.freenas.org/index.ph...es-9240-9211-w-ibm-seagate-disks.43453/page-2
https://forums.freenas.org/index.php?threads/solved-freenas-9-10-1-u4-scsi-status-error.48177/
