Hi all,
I'm trying to set up an EATON 5SC UPS with my FreeNAS system (see sig). The A1SAi-2750F only has two USB2.0 ports which are occupied by mirrored boot drives, so I need to connect the UPS to one of the rear USB3.0 ports. Here are my current BIOS settings:
I don't know which port to select in the UPS config in the FreeNAS GUI. When I connect the UPS to a USB3 port, nothing shows up in /var/log/messages. I tried a few other USB devices (USB3.0 flash drive, USB2.0 flash drive, USB2.0 mouse) but there were still no messages.
I've also tried configuring the UPS service in the FreeNAS GUI and starting the service. I selected the usbhid-ups driver and then went through each of the available ports, starting the service each time, but it doesn't start and I get the following console messages:
I have tried changing XHCI Hand-off to Enabled in the BIOS. With these settings I can boot but the outcome is the same as described. I can't boot if I change USB3.0 Support to Enabled.
Not sure what to try next so I would appreciate any suggestions.
Thanks for reading!
Tom
Legacy USB Support Enabled USB3.0 Support Disabled XHCI Hand-off Disabled EHCI Hand-off Enabled USB Mass Storage Driver Support Enabled Port 60/40 Emulation Enabled
Jul 27 23:08:54 xxxxxxxx notifier: Network UPS Tools - Generic HID driver 0.38 (2.7.2)
Jul 27 23:08:54 xxxxxxxx notifier: USB communication driver 0.32
Jul 27 23:08:54 xxxxxxxx notifier: No matching HID UPS found
Jul 27 23:08:54 xxxxxxxx notifier: Driver failed to start (exit status=1)
Jul 27 23:08:54 xxxxxxxx notifier: Network UPS Tools - UPS driver controller 2.7.2
Jul 27 23:08:54 xxxxxxxx root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Jul 27 23:08:54 xxxxxxxx notifier: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Jul 27 23:08:54 xxxxxxxx notifier: Starting nut_upsmon.
Jul 27 23:08:54 xxxxxxxx notifier: kill: No such process
Jul 27 23:08:54 xxxxxxxx notifier: UPS: ups (master) (power value 1)
Jul 27 23:08:54 xxxxxxxx notifier: Using power down flag file /etc/nokillpower
Jul 27 23:08:54 xxxxxxxx upsmon[29945]: UPS [ups]: connect failed: Connection failure: Connection refused
Jul 27 23:08:54 xxxxxxxx upsmon[29945]: Communications with UPS ups lost
Broadcast Message from root@xxxxxxxx.xxxx
(no tty) at 23:08 CEST...
Jul 27 23:08:55 xxxxxxxx notifier: Starting nut_upslog.
Jul 27 23:08:55 xxxxxxxx notifier: Warning: initial connect failed: Connection failure: Connection refused
Jul 27 23:08:56 xxxxxxxx notifier: Stopping nut_upslog.
Jul 27 23:08:56 xxxxxxxx notifier: Waiting for PIDS: 29965.
Jul 27 23:08:56 xxxxxxxx notifier: Stopping nut_upsmon.
Jul 27 23:09:17 xxxxxxxx afpd[26012]: AFP logout by sbp
Jul 27 23:09:17 xxxxxxxx afpd[26012]: AFP statistics: 373541.51 KB read, 130120.76 KB written
Jul 27 23:09:17 xxxxxxxx afpd[26012]: done
Jul 27 23:09:20 xxxxxxxx upsmon[29944]: upsmon parent: read
Jul 27 23:09:20 xxxxxxxx notifier: Waiting for PIDS: 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945, 29945.
Jul 27 23:09:21 xxxxxxxx notifier: nut not running? (check /var/db/nut/upsd.pid).I have tried changing XHCI Hand-off to Enabled in the BIOS. With these settings I can boot but the outcome is the same as described. I can't boot if I change USB3.0 Support to Enabled.
Thanks for reading!
Tom
