DangerIsGo
- Nov 8, 2015
FreeNAS 9.3 STABLE
My friend recommended me try out NZBGet (over SABnzbd which has a proper plugin) so I had to do things a bit more manually.
I created the jail and web-consoled in.
I then did a
I then did a
Unfortunately, I am greeted with:
"/usr/ports/Mk/bsd.port.mk", line 1042: Unknown directive
Unknown modifier 't'
"/usr/ports/Mk/Uses/compiler.mk", line 149: warning: String comparison operator should be either == or !=
"/usr/ports/Mk/Uses/compiler.mk", line 149: Malformed conditional ((${COMPILER_TYPE} == clang && ${COMPILER_VERSION} < 35) || ${COMP
ILER_TYPE} == gcc)
"/usr/ports/Mk/bsd.port.mk", line 1741: Malformed conditional (defined(LLD_UNSAFE) && ${_TEST_LD:tA} == "/usr/bin/ld.lld")
"/usr/ports/Mk/bsd.port.mk", line 5357: if-less endif
make: fatal errors encountered -- cannot continue
Any ideas on what I might be doing wrong? And the reason I'm not doing
I then did a
portsnap fetch update
followed by a portsnap extract
.I then did a
cd /usr/ports/news/nzbget
followed by a make
.Unfortunately, I am greeted with:
ILER_TYPE} == gcc)
pkg install nzbget
is even though I did on a separate jail, it's using an older, broken version of nzbget. I need 18.1 for which they fixed the SSL. Thanks!!
