- Oct 29, 2016
why? just mirror your boot pool. built in function, handled for you, with GUI buttons. 2 small SSDs is like, maybe 100$? and since you will be dramatically under-provisioning them, they are unlikely to die in your lifetime. hell, in your descendants lifetime maybe.It'd be cool if you could partition half of it for boot, half for storage and then raid it.
again, using resources to increase reliability, because, again, remember, ENTERPRISE PRODUCT.
if you have followed anywhere even close to the recomended hardware, you have a system thats probably 800-1500$, plus fairly likely double that in spindle disks, and you are worried about .1% of that in "wasted" storage.
this "Wasted space" thing seems....just so silly honestly. its maybe 100GB (ok 200GB if you mirror it). its *nothing*.
you can get get 128GB RAM STICKS. and put 8 of them in a server.
M$, for example, wastes GB after GB for useless crap on a regular basis. im fine with allocating extra a negliglble amount of space to make my life easier.
ALL of my windows installs are about 80GB, usually on 120 or 240GB disks, because that's whats cheapest. windows and installed apps. everything else (media, games, random downloads and experiments, etc) is on other drives or my high reliability truenas. if windows dies, i reinstall it, nice and fresh.
if the drive dies....i replace it and reinstall windows.
if you want to do any of this, truenas is just not the way.
