Stelios Diamantis
 - Oct 7, 2016
Hi all,
today I've tried to upgrade my 9.3 to 9.10 through GUI. I did exactly what the "User Guide" suggests, changing the train to "FreeNAS-2.10-Stable" but the upgrade process stuck at 20% Installing base-os (1/5).
The
The
Any help will be highly appreciated.
The
 freenas-update check output is:Code:
Verify command = ['/usr/local/libexec/verify_signature', '-K', '/usr/local/share/certs/freenas-update.pem', '-C', '/usr/local/share/certs/iX-CA.pem', '-S', u'G9mTDUEqBulpjAJf5fWYkVtKd8ZR+Og69SF4g1rl4AvrIFoMVsmAAmMEvone0rGBy6/VuTQWVutRCnhIUC51uZhEe6iiJrvKcCUXaI+EhlPFL7EsZe6GmXNrwuJEFygFu/nlMtkHesy3Rb7tjTn7ygcux6PKW+l3pS5zDXqjQ4/153498hbhwMYutFZ/CUVvdRQMsu/bW8qu55PewisIZkpmWLC8b1PVUgnc5I6cyOM4tv04xZxerQYu8Tgh63xyDzWBtmuFm7xGSwpCaOnAquELsiMMiF3m2aDNJYC2SqrxwSXpINx6+kCvfuH31qQDz7e3hYmdcBR4OLs8TgIuVg==', '-R', '/tmp/tmpipA55a.pem'] Signature check succeeded Going to try checking cached manifest /var/db/system/update/MANIFEST Got this exception: [Errno 2] No such file or directory: '/var/db/system/update/MANIFEST' Status: No updates available Total Progress: [########################################] 100.00%
The
 beadm list output is:Code:
Initial-Install - - 2.5M 2015-10-18 01:05 Initial-Install Wizard-2015-10-18_01:17:47 - - 117.0K 2015-10-18 01:17 Wizard-2015-10-18_01:17:47 default - - 353.0K 2015-10-18 03:51 default FreeNAS-9.3-STABLE-201601181840 - - 137.3M 2016-01-26 01:16 FreeNAS-9.3-STABLE-201601181840 FreeNAS-9.3-STABLE-201602031011 - - 139.0M 2016-02-20 15:05 FreeNAS-9.3-STABLE-201602031011 FreeNAS-9.3-STABLE-201604120241 - - 160.0M 2016-04-14 19:57 FreeNAS-9.3-STABLE-201604120241 FreeNAS-9.3-STABLE-201605170422 N / 538.6M 2016-08-27 10:20 FreeNAS-9.3-STABLE-201605170422 FreeNAS-b4dd4ba2806e14bf8fc4ce58d78d22cf-1 R - 2.1G 2016-10-07 21:19 FreeNAS-b4dd4ba2806e14bf8fc4ce58d78d22cf-1
