Cannot unmount /var/db/system/syslog - device busy
bob p
I'm trying to do a zpool export and I'm being stopped by a "Device busy" error. AFICT this was a bug once upon a time, that was fixed in 9.2. I'm having it in the most recent version, 9.10-STABLE:
# zpool export poolname
cannot unmount '/var/db/system/syslog-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx': Device busy
What am I missing?
Robert Trevellyan
Pony Wrangler
Is your .system dataset stored on the pool you're trying to export? If so, you need to move it to another pool.
bob p
I don't think so -- I'm trying to export the storage pool, which is located under /mnt/poolname. AFAIK the .system dataset is stored on the USB drive in the default configuration, isn't it?
