cannot select ZVol on VM GUI for VM devices
Peter Hood
I tried to setup a VM with the new GUI on FreeNAS-9.10-MASTER-201703080410.
Everything works perfect except that i cannot select a ZVol while setting up a DISK device for the VM.
The selection field is just empty.
Also if i select VirtIO in the Mode Field for the DISK device the selection will not be saved but AHCI Mode stays selected.
Another question regarding iohyve.
After i created a VM with the GUI im able to start and stop the VM via GUI but i cannot see the VM on the console
using the iohyve commands
(e.g.: iohyve list) shows that there is no VM present at all.?
Kris Moore
SVP of Engineering
Administrator
The VM UI doesn't use 'iohyve' in the backend, so VM's created there won't show up with that command. Please open a ticket about the zvol issue though so we can take a look.
tfast500
I am seeing the same thing where I am trying to add a disk and the zvol selection shows empty
EDIT:
After finding the bug report - I found that the issue was that I also did not create the zvol inside the pool... :P
