Hi, I can't pull data from a remote machine. The configuration and ssh keys are working. I am confused with the UTC, but have tried several times and failed to pull data?
I can pull via terminal commands.
FreeNAS-9.10.2-U4 (27ae72978)
Rsync path: /mnt/Volume1/dump
User: root
Remote Host: 192.168.1.140
Remote SSH Port: 22
Rsync mode: Rsync over SSH
Remote Path: /var/lib/vz/dump
Validate Remote Path: ticked.
Direction: Pull
Short description: Pull backups from remote machine
Minute: Each selected minute: 5 minutes after current time for a test
Hour: Each selected hour: hour according to UTC calculator to current hour, for a test
Day of month: Each selected day of month: day according to UTC calculator to current time, for a test
Month: all ticked
Day of week: all ticked
Recursive: ticked
Times: ticked
Compress: ticked
Delay Updates: ticekd
Extra options: --remove-source-files
Enabled: ticked
User: root
Remote SSH Port: 22
Direction: Pull
Month: all ticked
Recursive: ticked
Times: ticked
Compress: ticked
Enabled: ticked
