SOLVED Cannot apply ACL to dataset
soft_reset
First, my setup: I'm running freenas 11.3, joined to a Windows2019 AD. I have a pool with datasets.
An AD user and an AD group both had full access to this dataset via ACL settings.
After a reboot, my root password no longer worked, and after I reset it, all my configured shares were gone.
When trying to set them up again, I ran into this error message:
"Error: [dacl] Item#2 is not valid per list types: [id] Not an integer "
Actually, now that I tried again, I get this error instead:
This appears for any AD user or group I try to add to the ACL list. I can change and save permissions for group@ and owner@.
EDIT: For some reason I got it to work, with as far as I can tell the same steps...
I repeated my steps a dozen times and it didn't work. Then I made a new dataset, and applied the same settings to it that gave me uid error before; one user, one group, default acls with full control. On the new dataset it worked.
After that I tried again on my old dataset, and now that works as well.
Sorry for making this empty thread I guess, I have no idea how this happened or why it works now. I also still don't know why my password and config were gone after a reboot. thank you for your time.
Rudi Swennen
Hello soft_reset, I have the same issue with 11.3 and the 12.0-Ux releases. After a few hours/days it just "automagically" works
* wbinfo -{ugP} just works from the start and delivers correct info.
* In 12.0 I get additionally a lot of "pam_reinitialized_cred" not implemented errors.
So not solved for me :-s
Rudi Swennen
The pam_reinitialized_cred errors are not the only one ... after a few leave-rejoin AD domain the errors "change".
Someone an idea?
Windows server 2019 is patched to the latest version.
