Cannot access HTTP with fresh install on 8.3.1
trevorault
I have been using FreeNAS for over 4 years on an Intel SS4200 NAS without many issues. Recently the system would stop sharing NFS and AFP shares and would not be accessible via HTTP. It would come back online and work properly with a reboot. I upgraded to 9.1.0 and it seemed to be working fine. Then I lost connection to the shares and HTTP again and couldn't get them back after rebooting. I decided to load a fresh install of 9.1.0 to my USB drive, but auto import of the ZFS share would not work. So I loaded 8.3.1 on the USB drive and now get the following error when trying to access via HTTP (also attached file with error messages). I bought a brand new USB drive and get the same error. What is going on? I'm hoping the ZFS pool (I believe it is RAID5 ZFS version 28) is OK and I can import as soon as I get FreeNAS working. Does this sound like a hardware issue? If so, if I install on a new system with the same 4 1.5 TB SATA HDD will I be able to import the zpool and save the data? I appreciate any help.
Request Method: GET
Request URL: http://192.168.5.3/
Software Version: FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty)
Exception Type: SuspiciousOperation
Exception Value:
Invalid characters in session key
Exception Location: /usr/local/lib/python2.7/site-packages/django/contrib/sessions/backends/file.py in _key_to_file, line 43
Server time:
Thu, 22 Aug 2013 22:05:15 -0700
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
VariableValue
csrftoken 'b3dd9160805b3bdcc51b83affe61b5c3'
fntreeSaveSelectedCookie 'root%2F163'
mytreeSaveStateCookie 'root%2C2%2C5%2C30%2C16%2C12%2C84%2C92%2C19%2C93%2C76%2C85%2C96%2C8%2C94%2C98%2C47%2C54%2C1%2C79%2C80%2C55%2C65%2C13%2C29%2C23%2C135%2C137'
sessionid 'cs4c0mn348xab7z67ubiqyevxl44pvpx'
fntreeSaveStateCookie 'root%2Croot%2F100%2Croot%2F100%2F114%2Croot%2F119%2Croot%2F117%2Croot%2F117%2F149%2F150%2Croot%2F53%2F54%2Croot%2F53%2Croot%2F53%2F57%2Croot%2F1%2Croot%2F1%2F8%2Croot%2F1%2F5%2Croot%2F82%2Croot%2F55%2Croot%2F55%2F69%2Croot%2F55%2F62%2Croot%2F12'
META
VariableValue
wsgi.multiprocess False
HTTP_COOKIE 'fntreeSaveStateCookie=root%2Croot%2F100%2Croot%2F100%2F114%2Croot%2F119%2Croot%2F117%2Croot%2F117%2F149%2F150%2Croot%2F53%2F54%2Croot%2F53%2Croot%2F53%2F57%2Croot%2F1%2Croot%2F1%2F8%2Croot%2F1%2F5%2Croot%2F82%2Croot%2F55%2Croot%2F55%2F69%2Croot%2F55%2F62%2Croot%2F12; csrftoken=b3dd9160805b3bdcc51b83affe61b5c3; sessionid=cs4c0mn348xab7z67ubiqyevxl44pvpx; fntreeSaveSelectedCookie=root%2F163; mytreeSaveStateCookie=root%2C2%2C5%2C30%2C16%2C12%2C84%2C92%2C19%2C93%2C76%2C85%2C96%2C8%2C94%2C98%2C47%2C54%2C1%2C79%2C80%2C55%2C65%2C13%2C29%2C23%2C135%2C137'
REDIRECT_STATUS '200'
SERVER_SOFTWARE 'nginx/1.2.2'
SCRIPT_NAME u''
REQUEST_METHOD 'GET'
PATH_INFO u'/'
SERVER_PROTOCOL 'HTTP/1.1'
QUERY_STRING ''
CONTENT_LENGTH ''
HTTP_USER_AGENT 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_8_4) AppleWebKit/536.30.1 (KHTML, like Gecko) Version/6.0.5 Safari/536.30.1'
HTTP_CONNECTION 'keep-alive'
SERVER_NAME 'localhost'
REMOTE_PORT '62289'
wsgi.url_scheme 'http'
SERVER_PORT '80'
SERVER_ADDR '192.168.5.3'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
DOCUMENT_URI '/'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x808398c90>
HTTP_HOST '192.168.5.3'
wsgi.multithread True
REQUEST_URI '/'
HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
wsgi.version (1, 0)
GATEWAY_INTERFACE 'CGI/1.1'
wsgi.run_once False
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x8083986d0>
REMOTE_ADDR '192.168.5.13'
HTTP_ACCEPT_LANGUAGE 'en-us'
CONTENT_TYPE ''
CSRF_COOKIE 'b3dd9160805b3bdcc51b83affe61b5c3'
HTTP_ACCEPT_ENCODING 'gzip, deflate'
  • freenas error 20130822.txt
D
dlavigne
Guest
Yeah, that was an error that occurred in firefox/safari browsers that was fixed in 9.x. Do you have access to another web browser?
What sort of errors were you getting when trying to import the pool?
trevorault
I reloaded the USB drive with 9.1.0 and got FreeNAS booted. Now I got the following error when I imported the zpool:
I also checked the status with -v and the files with permanent errors are all TimeMachine files, so that is OK. I just want to recover my other files. Is there a way to do this?
trevorault
I'm not sure if the error message is accessible above in the attached file so here is a copy:
[root@freenas] ~# zpool status -v
pool: Carlos
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: resilvered 6.95G in 0h9m with 25724 errors on Fri Aug 23 07:00:37 2013
NAME STATE READ WRITE CKSUM
Carlos DEGRADED 0 0 31.6K
raidz1-0 DEGRADED 0 0 84.4K
gptid/b2600453-714d-11e1-90bd-00151731e8a6 ONLINE 0 0 186
gptid/b2afe3dd-714d-11e1-90bd-00151731e8a6 FAULTED 47 1.32K 28 too many errors
gptid/b2feb193-714d-11e1-90bd-00151731e8a6 ONLINE 0 0 0
gptid/b34e3de7-714d-11e1-90bd-00151731e8a6 ONLINE 0 0 0
Do you can fix this on 8.3.2 too?
I cannot work witn 9.1.1, may be 2GB memory not enough...
