I was running FreeNAS 9.10 for 10 years on a HP MicroServer N36L Athlon2 1,3GHZ DualCore with 8GB of RAM and I decided to do a fresh install of trueNAS 12. (TrueNAS-12.1-MASTER-20210.)
After the installation I tried to import my old pool via WebGUI but I received the following error:
I tried to do a service middlewared restart and import after it, but without any success.
Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.8/concurrent/futures/process.py", line 239, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 94, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 45, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 371, in import_pool self.logger.error( File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__ File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 365, in import_pool zfs.import_pool(found, new_name or found.name, options, any_host=any_host) File "libzfs.pyx", line 1095, in libzfs.ZFS.import_pool File "libzfs.pyx", line 1123, in libzfs.ZFS.__import_pool libzfs.ZFSException: '/data/zfs' is not a valid directory """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 367, in run await self.future File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 403, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool.py", line 1411, in import_pool await self.middleware.call('zfs.pool.import_pool', pool['guid'], { File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call return await self._call( File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1203, in _call return await self._call_worker(name, *prepared_call.args) File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1209, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1136, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) libzfs.ZFSException: ("'/data/zfs' is not a valid directory",)
