- Apr 19, 2014
Two new threads in one week, I'm a little disappointed in myself! I kicked off a scrub today so I can safely pull out a defective drive that's been giving me some SMART errors (OfflineUncorrectableSector) and get it RMAed. During that scrub I noticed this error in the web UI's console output:
The OfflineUncorrectableSector are on a different drive, so I don't think it's related. But I thought it'd be worth mentioning here first.
Here's the output of: smartctl -q noserial -a /dev/ada6
Am I translating that SMART output correctly in that there's not really anything all that concerning in there?
I've been digging around all the CAM status: Uncorrectable parity/CRC error threads I can find in the forum and one of the suggestions seems to be swapping cables on that particular drive or trying it in a different SATA port. Is that a good next step?
I tweaked the scheduled SMART tests to run the long test tomorrow morning morning, is there a way to kick them off manually?
Again, thanks in advance for the help not only in this thread but all the other similar ones I've been digging through. Sorry if I overlooked my answer if it's in another thread!
Sep 24 17:44:57 DrTeeth kernel: (ada6:ahcich4:0:0:0): READ_FPDMA_QUEUED. ACB: 60 18 b8 90 c7 40 07 00 00 00 00 00 Sep 24 17:44:57 DrTeeth kernel: (ada6:ahcich4:0:0:0): CAM status: Uncorrectable parity/CRC error Sep 24 17:44:57 DrTeeth kernel: (ada6:ahcich4:0:0:0): Retrying command
[root@DrTeeth] ~# smartctl -q noserial -a /dev/ada6 smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red (AF) Device Model: WDC WD20EFRX-68AX9N0 Firmware Version: 80.00A80 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Sep 24 18:04:54 2014 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (27600) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 279) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 177 175 021 Pre-fail Always - 4133 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 14 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3859 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 14 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 11 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2 194 Temperature_Celsius 0x0022 108 106 000 Old_age Always - 39 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 5 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. [root@DrTeeth] ~#
