codenamezero
- Sep 4, 2011
Hi guys,
Kind a new here, I'd like to know when do i need to worry about the health of my disk and when I should replace it (possibly before it fails)?
I ran the command on one of my disk, but not really sure how to interpret the result.
freenas# smartctl -a /dev/ada1
smartctl 5.40 2010-10-16 r3189 [FreeBSD 8.2-RELEASE-p1 amd64] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
Device Model: ST2000DL003-9VT166
Serial Number: 5YD33RP5
Firmware Version: CC32
User Capacity: 2,000,398,934,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Dec 4 13:54:12 2011 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 623) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
SCT capabilities: (0x30b7) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 226580152
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 41
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 065 060 030 Pre-fail Always - 3456725
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2254
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 49
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 067 060 045 Old_age Always - 33 (Min/Max 28/39)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 28
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 46
194 Temperature_Celsius 0x0022 033 040 000 Old_age Always - 33 (0 25 0 0)
195 Hardware_ECC_Recovered 0x001a 023 007 000 Old_age Always - 226580152
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 171519518968015
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 369852950
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3759858796
