CAM status: Uncorrectable parity/CRC error on 5 drives
SwisherSweet
I'm getting CAM status: Uncorrectable parity/CRC error on 5 drives according to my dialy security output run. I appreciate any help and advice on how to proceed next to keep my data protected.
(ada5:mvsch1:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 e8 18 4e 63 40 9a 00 00 00 00 00
(ada6:mvsch1:0:1:0): WRITE_FPDMA_QUEUED. ACB: 61 a8 98 59 63 40 9a 00 00 00 00 00
(ada8:mvsch1:0:3:0): WRITE_FPDMA_QUEUED. ACB: 61 f0 c0 4d 63 40 9a 00 00 00 00 00
(ada7:mvsch1:0:2:0): WRITE_FPDMA_QUEUED. ACB: 61 00 c0 4c 63 40 9a 00 00 01 00 00
(ada9:mvsch1:0:4:0): WRITE_FPDMA_QUEUED. ACB: 61 f0 e8 50 63 40 9a 00 00 00 00 00
(ada5:mvsch1:0:0:0): CAM status: Uncorrectable parity/CRC error
(ada6:mvsch1:0:1:0): CAM status: Uncorrectable parity/CRC error
(ada5:(ada6:(ada7:mvsch1:0:2:0): CAM status: Uncorrectable parity/CRC error
mvsch1:0:(ada8:mvsch1:0:3:0): CAM status: Uncorrectable parity/CRC error
1:(ada7:0): mvsch1:0:Retrying command
2:(ada8:0): mvsch1:0:Retrying command
3:0): (ada9:mvsch1:0:4:0): CAM status: Uncorrectable parity/CRC error
Retrying command
(ada9:mvsch1:0:mvsch1:0:4:0:0): 0): Retrying command
Retrying command
(ada9:mvsch1:0:4:0): WRITE_FPDMA_QUEUED. ACB: 61 f8 b8 bd 12 40 9f 00 00 00 00 00
(ada7:mvsch1:0:2:0): WRITE_FPDMA_QUEUED. ACB: 61 d8 90 ba 12 40 9f 00 00 00 00 00
(ada5:mvsch1:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 f0 c0 bd 12 40 9f 00 00 00 00 00
(ada6:mvsch1:0:1:0): WRITE_FPDMA_QUEUED. ACB: 61 f8 70 c2 12 40 9f 00 00 00 00 00
(ada8:mvsch1:0:3:0): WRITE_FPDMA_QUEUED. ACB: 61 f8 b8 bd 12 40 9f 00 00 00 00 00
(ada9:(ada7:mvsch1:0:mvsch1:0:4:2:0): 0): Retrying command
Retrying command
(ada8:mvsch1:0:(ada6:mvsch1:0:1:0): CAM status: Uncorrectable parity/CRC error
3:(ada6:0): mvsch1:0:Retrying command
1:0): (ada5:mvsch1:0:0:0): CAM status: Uncorrectable parity/CRC error
Retrying command
(ada5:mvsch1:0:0:0): Retrying command
Here are the errors summarized:
I have verified that all of these drives are in the same external eSATA enclosure (either backup1 or backup2... hard to know since FreeNAS doesn't tell which drives map to which volume(s)).
All volumes show healthy.
A little more setup information:
  • Mac Pro, 2 x 6 Core 3.46Hz Xeons, 64gb ECC RAM
  • FreeNAS-9.10.2-U6 (561f0d7a1)
  • 7 x 3TB Toshiba drives in "primary" data pool in raidz2
  • 5 x 2TB Seagate drives in "backup1" backup pool (externally attached) in raidz1
  • 5 x 2TB Seagate drives in "backup2" backup pool (externally attached) in raidz1
My questions are:
  1. Do these errors mean?
  2. Is it likely there has been data loss?
  3. What should be my next steps to prevent (further) data loss?
Thank you.
If you have one try replacing the e-sata cable, e-sata is notoriously picky about cables, you're also using a port multiplier than can makes things even worse.
SwisherSweet
Thanks for the replies. I'll swap out the cables and see. I did notice that this started happening about a month ago and gets report on each scrub of that pool.
I ran a zpool status and all pools and there are no errors, so can I conclude there is a hardware issue only at this point?
Yes, it means there's was a CRC error during the transfer from the disk(s), when this happens there's a retry so your data is not affected, most times it means a bad SATA cable, also usually the SMART attribute 199 (UltraDMA CRC Error Count) will increase by one each time there's an error.
joeschmuck
Old Man
Also know that attribute ID 199 will live with the hard drive forever so if you have a count of 28, this does not mean there is anything wrong with the drive based on your specific situation. Just note the fact that you have those errors and move on. Hopefully a new eSATA cable fixes your issue.
No, you need to run the scrub. A zpool status is only a status message. Running a scrub will pass all that data through the new eSATA cable and then if you have no issues then you can call it fixed and point the finger at a bad cable.
