Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@freenas[~]# badblocks -b 4096 -vws /dev/ada0
Checking for bad blocks in read-write mode
From block 0 to 1953506645
Testing with pattern 0xaa: set_o_direct: Inappropriate ioctl for device
done
Reading and comparing: done
Testing with pattern 0x55: done
Testing with pattern 0xff: done
Testing with pattern 0x00: done
Pass completed, 0 bad blocks found. (0/0/0 errors)
root@freenas[~]#
root@freenas[~]# badblocks -b 4096 -vws /dev/ada1
done
root@freenas[~]#
root@freenas[~]# badblocks -b 4096 -vws /dev/ada2
done
root@freenas[~]#
root@freenas[~]# badblocks -b 4096 -vws /dev/ada3
done
root@freenas[~]#
root@freenas[~]# smartctl -a /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate IronWolf
Device Model: ST8000VN0022-2EL112
Serial Number: ZA1DXYPW
LU WWN Device Id: 5 000c50 0b3964d74
Firmware Version: SC61
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Dec 17 08:19:33 2018 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 804) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 081 064 044 Pre-fail Always - 134368050
3 Spin_Up_Time 0x0003 098 098 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 1
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 71635666
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 284
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 1
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 076 069 040 Old_age Always - 24 (Min/Max 18/31)
191 G-Sense_Error_Rate 0x0032 098 098 000 Old_age Always - 4625
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 2
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1078
194 Temperature_Celsius 0x0022 024 040 000 Old_age Always - 24 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 006 006 000 Old_age Always - 134368050
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 257 (56 119 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 62599620626
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 64026522399
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 259 -
# 2 Extended offline Completed without error 00% 57 -
# 3 Conveyance offline Completed without error 00% 45 -
# 4 Short offline Completed without error 00% 45 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@freenas[~]#
root@freenas[~]# smartctl -a /dev/ada1
Serial Number: ZA1DXY4C
LU WWN Device Id: 5 000c50 0b39620d2
Local Time is: Mon Dec 17 08:26:22 2018 CET
been run.
command.
power-saving mode.
recommended polling time: ( 791) minutes.
1 Raw_Read_Error_Rate 0x000f 076 064 044 Pre-fail Always - 42761010
7 Seek_Error_Rate 0x000f 078 060 045 Pre-fail Always - 70599130
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 285
191 G-Sense_Error_Rate 0x0032 099 099 000 Old_age Always - 2673
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 973
195 Hardware_ECC_Recovered 0x001a 006 006 000 Old_age Always - 42761010
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 257 (84 206 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 62599657314
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 64026237693
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@freenas[~]# smartctl -a /dev/ada2
Serial Number: ZA1E06LM
LU WWN Device Id: 5 000c50 0b39624ae
Local Time is: Mon Dec 17 08:26:32 2018 CET
been run.
command.
power-saving mode.
recommended polling time: ( 796) minutes.
1 Raw_Read_Error_Rate 0x000f 074 064 044 Pre-fail Always - 26633778
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 71170760
191 G-Sense_Error_Rate 0x0032 098 098 000 Old_age Always - 4610
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1112
195 Hardware_ECC_Recovered 0x001a 006 006 000 Old_age Always - 26633778
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 258 (130 9 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 62599631258
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 64025907487
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@freenas[~]# smartctl -a /dev/ada3
Serial Number: ZA1DXXBV
LU WWN Device Id: 5 000c50 0b3963246
Local Time is: Mon Dec 17 08:26:37 2018 CET
been run.
command.
power-saving mode.
recommended polling time: ( 794) minutes.
1 Raw_Read_Error_Rate 0x000f 082 064 044 Pre-fail Always - 168433970
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 70907741
190 Airflow_Temperature_Cel 0x0022 075 068 040 Old_age Always - 25 (Min/Max 18/32)
191 G-Sense_Error_Rate 0x0032 098 098 000 Old_age Always - 4858
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1072
194 Temperature_Celsius 0x0022 025 040 000 Old_age Always - 25 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 006 006 000 Old_age Always - 168433970
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 258 (164 63 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 62599670922
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 64025922301
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@freenas[~]#
