MattyNAs
- Feb 15, 2017
I'm trying to setup an entertainment Hub for different Vehicles. I was thinking of buying a cheaper NAS enclosure (with, maybe a WD Red 1 or 2T HDD ), install FreeNAS, and also activate the plex plugin, and then connect the setup to a router (these will be setup in about 20 vehicles)
1. What will be the best & cost effective way to set this up, since I will be doing this for a lot of buses?
2. There's is also the issue of transcoding the media files, do i need to take this into consideration in getting the hardware?
3. Can the FreeNAS OS be installed on any NAS device?
Thanks
Thanks
