I started w/ a very common build i saw 1.5 years ago to get me started w/ freenas. I use my server primarily as a media server (plex) and backups. I thought I would only be using 2-3 streams at the most...but I've found that after some of my colleagues have deployed to afghanistan, I've been doing 3+ streams simultaneously. The biggest issues i saw w/ my avoton system was playback for certain types files (mkv). I suspect i'll be using it like this consistently as I won't deprive my buds overseas from entertainment. Although I don't have any catastrophic issues w/ streaming....the encoding of those files are becoming a serious issue w/ playback and i'm nervous about obvious limitations.
Current build:
Asrock C2550d4i
32 GB ECC ram
6 x 3TB WD Red, RaidZ2
Fractal Node 304
My question: What is the most cost effective and capable mobo/cpu upgrade?
1) skylake xeon v5 w/ supermicro X11 mobos? I don't feel my needs require x11 at this time, but since i'm upgrading...YOLO?
2) workhorse xeon 1231 v3 + SM X10SL7 mobo? This is a popular choice. New would cost me about 500 i think. However, i'd need to get a new case for the mATX form factor...which is an add'l 50-100 bucks as well...
3) xeon-d mobo? Seems to be avoton on steroids. I know the 1521 is better than the avoton, but will it be "futureproof" for my needs? Will I need the xeon d-1541 (X10SDV-TLN4F-O) ? That package would be 899!
Oh yea...i also have a i5-4670K in my desktop. It certainly doesn't need that kind of a cpu. Maybe get a supermicro x10 board and put an i5 on it?
Thoughts or other recs would be greatly appreciated.
Current build:
Asrock C2550d4i
32 GB ECC ram
Fractal Node 304
