Hi all. I'm new to here and new to using a NAS.
Currently, I'm in the process of building a pretty high tech motorhome that the Missus and I intend to start living in next year. I work online and will be working from the van. Most things to do this are sorted, but I need a storage solution.
I think a NAS makes most sense as it gives redundancy and avoids having to use a bunch of external drives. It would be hard-wired to the vehicles router (Huawei B315) and besides holding work stuff would act as a media server (is Plex best for this?)
It's the build I'm not 100% sure on.
From a PC I build a few years ago (again for mobile use), I have the following components:
i3 2100T low power processor
Mini ITX board
4 or 8GB Low Voltage Ram (what's better?)
128GB SSD
Pico 120w PSU (can run the PC on any voltage between 8v & 32v)
I'm then planning to add 2 x 6GB WD Red drives in Raid 1.
Everything needs to be low power. The PC at this moment runs @17w, with the extra drives it should run at a max of 25w.
Does this sound okay?
Or am I an idiot (and what would work better).
Thanks,
David
Mini ITX board
128GB SSD
Thanks,
David
