rdborg
- Dec 7, 2017
Hi to all, I have recently setup a dedicated ESXI host box for a small office enviornment with internal storage drives but the space & storage options are quite limited.
I need some opinions about a FreeNAS build i intend to use.
Basically i wish to build a deidcated FreeNAS machine with server grade hardware so on and also add a Quad Port NIC to via PIC-E to it.
The ESXI Host also has a quad nic with LACP connected to a capable enterprise netgear switch and setup with LACP as it serves 6-8 working desktops to thin clients... + some other low usage virtual servers no issue with network speed here.
My intention is to remove all drives from the ESXI box, place them in the NAS box and add some others and configure raid and then server an NFS/iSCSI from freenas as a data store on esxi that hold all virtual machine files..
Since they are fully working desktops for an office i think 1 GB connection would be saturated easily since the hdd data will be going to and from freenas/esxi and nost just remote desktop connection as it is directly at the moment
Finally my question is - Would LACP (quad intel nic) on the ESXI host and the FreeNAS machine with quad ports give better speeds when communicating to and from freen NFS datastore > ESXI host > Thin Clients & Back
Thanks
Ryan
Thanks
Ryan
