 - Apr 16, 2020
Hi All,
Not sure how to categorise this. Is it a bug, a feature, or that's the way it is?
Anyhow. The issue is with smart temperature and alerts.
Under services/s.m.a.r.t I can set some temperature thresholds that seem to apply to all the storage devices. This works.
The thing is that all storage devices are not created equal.
For instance - I have a DOM that boots freenas. This has different temperature thresholds than an HDD - yet the temp warning seems to apply to all equally.
Under storage/disks I have edited the device, enabled S.M.A.R.T. (I think irrelevant) and set the temperature thresholds for this device which are different from the HDD thresholds.
I still get warnings about the device using the general thresholds. I don't know if the disk specific settings are meant to override the general settings - but maybe they should.
