meredithkm
- Nov 8, 2020
Just wanted to identify something weird I found.
I have TRUENAS-MINI-3.0-E and after upgrading to 20.12 three of the ethernet adapters went unclaimed.
truenas# lshw -c net
*-network:0
description: Ethernet interface
product: Ethernet Connection X553 1GbE
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0f0
version: 11
serial: 70:85:c2:fa:4c:80
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list rom ethernet physical tp 10bt-fd 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=ixgbe driverversion=5.9.0-1-amd64 duplex=full firmware=0x80000877 ip=10.10.10.251 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:16 memory:ddc00000-dddfffff memory:dde04000-dde07fff memory:df680000-df6fffff memory:dfa00000-dfafffff memory:df900000-df9fffff
*-network:1 UNCLAIMED
description: Ethernet controller
physical id: 0.1
bus info: pci@0000:03:00.1
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress cap_list
configuration: latency=0
resources: memory:dda00000-ddbfffff memory:dde00000-dde03fff memory:df600000-df67ffff memory:df800000-df8fffff memory:df700000-df7fffff
*-network:0 UNCLAIMED
physical id: 0
bus info: pci@0000:05:00.0
version: 11
width: 64 bits
clock: 33MHz
resources: memory:dd600000-dd7fffff memory:dd804000-dd807fff memory:df180000-df1fffff memory:df500000-df5fffff memory:df400000-df4fffff
physical id: 0.1
bus info: pci@0000:05:00.1
version: 11
width: 64 bits
clock: 33MHz
resources: memory:dd400000-dd5fffff memory:dd800000-dd803fff memory:df100000-df17ffff memory:df300000-df3fffff memory:df200000-df2fffff
I went ahead and reverted to SCALE 20.10 for now as I currently need the additional adapters. I would be happy to do any testing including the update if it would help with testing.
Please keep up the great work!
*-network:0
physical id: 0
version: 11
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
physical id: 0.1
version: 11
width: 64 bits
clock: 33MHz
physical id: 0
version: 11
width: 64 bits
clock: 33MHz
physical id: 0.1
version: 11
width: 64 bits
clock: 33MHz
