arnaudf9
- Jul 19, 2022
Hello Truenas community, I've just finished assembling a NAS server running Truenas Scale. My goal is to run multiple VMs, including one that I'd like the integrated graphics from my CPU to be passthrough to that VM.
My hardware:
- Supermicro X11SCL-F
- CORE I3-8300 3.70GHZ 8M LGA1151
When creating a VM, I can select the GPU to be passthrough to the VM. I unfortunately only see the onboard one from the motherboard (ASPEED Graphics Family), not the one from the CPU.
Things I've tried/command run to troubleshoot:
- When looking in the bios, I do not see an option to enable it. I followed this https://ahelpme.com/servers/supermicro/enable-internal-graphics-in-supermicro-servers/ and the "Graphics Configuration" option is not there.
- Tried this https://github.com/intel/intel-device-plugins-for-kubernetes/blob/main/cmd/gpu_plugin/README.md however I do end up in the error state, e.g. "0/1 nodes are available: 1 Insufficient gpu.intel.com/i915"
^ This one is the one from the motherboard. The iGPU one was not detected.
So I'm stuck. It doesn't seem the system is able to see my iGPU, nor does the BIOS? How is that possible? Is somehow the motherboard the issue?
My hardware:
root@truenas[~]# ls -la /dev/dri total 0 drwxr-xr-x 3 root root 80 Jul 19 14:54 . drwxr-xr-x 20 root root 3660 Jul 19 14:58 .. drwxr-xr-x 2 root root 60 Jul 19 14:54 by-path crw-rw---- 1 root video 226, 0 Jul 19 14:54 card0
root@truenas[~]# ls -la /sys/class/drm/card? lrwxrwxrwx 1 root root 0 Jul 19 14:54 /sys/class/drm/card0 -> ../../devices/pci0000:00/0000:00:1c.1/0000:07:00.0/0000:08:00.0/drm/card0
root@truenas[~]# lshw -c video
*-display
description: VGA compatible controller
product: ASPEED Graphics Family
vendor: ASPEED Technology, Inc.
physical id: 0
bus info: pci@0000:08:00.0
version: 41
width: 32 bits
clock: 33MHz
capabilities: pm msi vga_controller cap_list rom
configuration: driver=ast latency=0
resources: irq:17 memory:90000000-90ffffff memory:91000000-9101ffff ioport:3000(size=128) memory:c0000-dffff#^ This one is the one from the motherboard. The iGPU one was not detected.
