FreeNAS 11.3 with 2 Gigabit ports
pfSense is DHCP
pfSense has static IP mapping for both nics and IPMI.
If both NICs are connected, (both ethernet cables are plugged in at the same time) I get some sort of broadcast network storm (the switches all blink in a super fast synchrony steady pattern). This shuts the network down until I disconnect one of the ethernet cables. Ive tried different cables and a different switch and still same issue. If one cable is connected, I have no issues. It doesn't matter which ONE NIC is connected. Connect them both....BOOM the activity lights go nuts. What is causing this. PLEX is off, VM is off.
I can access web GUI no problem with one NIC connected. But always get The Web interface could not bind to 192.168.5.50. Using 0.0.0.0 instead. I don't see where I have that IP address set ANYWHERE in the GUI. How can I get that IP address OUT of the config file?
			pfSense is DHCP
