When I use a bridge between my 10Gb NIC and 1Gb NIC, the SMB read speeds are slow. Write is fine.
iperf3 -B <macbook> -c <server> -t 60 gives around 8-9Gbit for send/receive.
iperf3 -R -B <macbook> -c <server> -t 60 gives me only 900Mbit.......
Using blackmagic test, I get like 800mbyte/s write speed but only 110 mbyte read speed over SMB.
When I remove the bridge, blackmagic speed test writes and reads about 900Mbyte/sec to and from my pool.
Changing the hardware offloading doesn't really help. It makes things worse it seems.
The bridge is not used for jails/VMs, they have a separate port on a 1GB NIC.
I am running Core 13-u6.1. I am not sure if the speed changed by the latest TN updates or not as I upgraded my server last week. I also then did a clean install of 13u6 to SSDs and then upgrade to 6.1 last week (so no older legacy versions left on the boot pool; imported the config).
Any thoughts?
Thanks.
Any thoughts?
Thanks.
