"boot-pool uncorrectable I/O failure" error & unknown SMART attributes
FlyingPersian
I'm on a relatively fresh (2-3 weeks) TN instal on my 2,5" SSD, which is connected to the internal motherboard USB connector via a SATA to USB Adapter. Today, my NAS has been running for a few hours, when I noticed I couldn't access it via the GUI. IPMI showed me that there was an errro with the boot-pool. Shutting the server down via console was not possible (see screenshot below). Connecting via SSH did not work as well (no error, just kept trying to connect):
After a reset. I ran a few tests and some things seemed weird:
1. One of my drives is shown as ada3p2, the rest as gptid/xxx:
        Data                                            ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/111dd78e-103b-11e9-b74e-0cc47a406253  ONLINE       0     0     0
            gptid/f862c9ea-00b4-11ea-9daf-0cc47a406253  ONLINE       0     0     0
            gptid/e79d9e0e-f731-11e9-9ef4-0cc47a406253  ONLINE       0     0     0
            gptid/ed4cf2d0-e4eb-11e8-bded-0cc47a406253  ONLINE       0     0     0
            ada3p2                                      ONLINE       0     0     0
            gptid/b9c40f77-68f3-11e8-a08d-0cc47a406253  ONLINE       0     0     0
2. A quick SMART on my boot-pool revealed one error on an Unknown Attribute:
  1 Raw_Read_Error_Rate     0x0032   100   100   050    Old_age   Always       -       0
  5 Reallocated_Sector_Ct   0x0032   100   100   050    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   050    Old_age   Always       -       25
12 Power_Cycle_Count       0x0032   100   100   050    Old_age   Always       -       8
160 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       0
161 Unknown_Attribute       0x0033   100   100   050    Pre-fail  Always       -       100
163 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       32
164 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       21
165 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       1
166 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       0
167 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       0
168 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       7000
169 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       100
175 Program_Fail_Count_Chip 0x0032   100   100   050    Old_age   Always       -       0
176 Erase_Fail_Count_Chip   0x0032   100   100   050    Old_age   Always       -       0
177 Wear_Leveling_Count     0x0032   100   100   050    Old_age   Always       -       0
178 Used_Rsvd_Blk_Cnt_Chip  0x0032   100   100   050    Old_age   Always       -       0
181 Program_Fail_Cnt_Total  0x0032   100   100   050    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   050    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   050    Old_age   Always       -       8
194 Temperature_Celsius     0x0022   100   100   050    Old_age   Always       -       43
195 Hardware_ECC_Recovered  0x0032   100   100   050    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   100   100   050    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   050    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0032   100   100   050    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   050    Old_age   Always       -       0
232 Available_Reservd_Space 0x0032   100   100   050    Old_age   Always       -       100
241 Total_LBAs_Written      0x0030   100   100   050    Old_age   Offline      -       43
242 Total_LBAs_Read         0x0030   100   100   050    Old_age   Offline      -       53
245 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       0
My guess is that it has something to do with the Adapter? The SSD is quite new (25h run-time). Is there any way I can verify without buying a new one? My motherboard (Supermicro X10SLM-F) has 6 SATA ports, which are all in use.
HoneyBadger
actually does care
Administrator
What model of SSD? Certain ones (I believe using a SiliconMotion controller, eg: WD Green) have an issue with self-corroding when issued TRIM commands. Only solution is to disable TRIM which is unfortunately a global setting.
FlyingPersian
Intenso High Performance interne SSD 120GB. The spec sheet says:
Properties: Advanced 3D-Nand technology with SLC data boost-cache*
            Low power consumption
            Schock-resistant (1500 G / 0.5 ms)
            Silent operation (0 dB)
Features: SMART Command Support
          TRIM Command Support
Edit: I can't find any information on the controller. On a different SSD from Intenso it says SandForce (SF 2281) Controller
Edit2: Happened again, this time with a slightly different message beforehand
Edit3: I changed out the cable since I had another one, and as of now (uptime 45 mins) I had no errors
HoneyBadger
actually does care
Administrator
HoneyBadger
actually does care
Administrator
I have saved the config yesterday. When I do a fresh install and upload the config, will it be fine or most likely corrupted as well?
Hard to say, but I assume you will be notified on config import if anything can't be parsed.
FlyingPersian
It should be clear in zpool status -v following a scrub. If the config database is listed in the corrupt files, you're going to have problems. If it's not in the list, all good.
A fresh install will be problematic as a lot of writes will happen before you can implement the trim setting. I saw a thread somewhere where there's a workaround for that too by going into command mode for the install and setting it at CLI first... Personally, I would just buy a $20 Kingston SSD and have an easier life.
robvandal999
I just installed TrueNAS 12.0 onto a 128gb thumb drive and I also am running into this issue. It is a brand new thumb drive too.
Kris Moore
SVP of Engineering
Administrator
Possibly related, some other users have let us know that using USB 2.0 or USB 1.1 ports for boot-pool work better than using USB 3.0.
