Boot Pool degraded. Is there a way to generate my configuration without access to Web UI?
drkokandy
Hi all,
My boot pool degraded today. Maybe a dud USB - just replaced it a few weeks ago when I got around to upgrading to 9.3.STABLE.
Anyway, my FreeNAS can start, but I receive multiple segmentation fault errors at boot, and the bottom line is, I cannot access the Web UI at all, but I can get command line access.
I tried scrubbing the boot pool, but it was too degraded to repair all files.
How is the configuration XML generated? Is there a way to generate the configuration XML from the command line?
Where is this configuration database stored? /data ? Because that appears to be intact.
I have a backup config file from a week or two ago, but I don't think it includes some recent changes I would like to salvage if possible.
Thanks for any insight anyone can provide
DaveF81
You can take a copy of /data/freenas-v1.0.db. You can then restore this into a new install of FreeNAS using the GUI.
The filename is actually /data/freenas-v1.db.
gpsguy
Active Member
drkokandy
Restoring from /data/freenas-v1.db worked perfectly and included all changes that weren't in the other backup - I personally didn't need to do anything /var/db/system. Thanks everyone.
