packinpennies
- Feb 11, 2018
My system was running stable with the boot pool living on a mirrored set of flash drives. Recently one failed, and the other went to a degraded state and showed errors as well, so I decided to replace the flash drives with an internal SSD. I took a backup of the FreeNAS configuration, and then booted from a flash drive with the installation media on it and installed it to the SSD. Next, I went to the web GUI and uploaded the config backup I took recently.
After rebooting, I noticed the pool had a handful of errors, so I ran a scrub. This is the result when I input zpool status -v into the shell:
Clearly this is not ideal. So, I did a fresh install and loaded from my config with the same result.
My question is, does this indicate that my SSD is damaged/corrupted, or just that the config I took was corrupted to begin with? I really don't want to have to go purchase another SSD.
Thanks!
pool: freenas-boot
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0 days 00:00:02 with 30 errors on Sun Feb 3 12:11:52 2019
NAME STATE READ WRITE CKSUM
freenas-boot DEGRADED 0 0 72
ada4p2 DEGRADED 0 0 186 too many errors
<metadata>:<0x26>
freenas-boot/ROOT/default@2019-02-03-16:57:45:<0x0>
freenas-boot/ROOT/default@2019-02-03-16:57:45:/data
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/idna/__pycache__/intranges.cpython-36.opt-1.pyc
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/lib-dynload
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/www/dojo/dojox/charting/widget/BidiSupport.js.map
freenas-boot/ROOT/default@2019-02-03-16:57:45:/boot/modules/amdgpu_vega10_sos_bin.ko
freenas-boot/ROOT/default@2019-02-03-16:57:45:/conf/base/etc/rc.shutdown.local
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/pytz/zoneinfo/Australia
freenas-boot/ROOT/default@2019-02-03-16:57:45:/boot/modules/radeon_SUMO_uvd_bin.ko
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/dojango/forms/__pycache__/formsets.cpython-36.opt-1.pyc
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/flask/__pycache__/logging.cpython-36.pyc
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/ldap/controls/__pycache__/libldap.cpython-36.pyc
freenas-boot/ROOT/default@2019-02-03-16:57:45:/boot/modules/radeon_TAHITI_uvd_bin.ko
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/django/contrib/auth/__pycache__/checks.cpython-36.opt-1.pyc
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/babel/locale-data/lv.dat
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/www/freenasUI/sharing/__pycache__
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/bin/hptraidconf
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/botocore/docs/__pycache__/paginator.cpython-36.opt-1.pyc
freenas-boot/ROOT/default@2019-02-03-16:57:45:/boot/modules/radeon_bonaire_uvd_bin.ko
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/share/locale/ja_JP.SJIS/LC_COLLATE
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/www/freenasUI/plugins/__pycache__
freenas-boot/ROOT/default@2019-02-03-16:57:45:/usr/local/lib/python3.6/site-packages/pytz/zoneinfo/Etc
freenas-boot/ROOT/default@2019-02-03-16:57:45:/boot/modules/radeon_hawaii_uvd_bin.ko
freenas-boot/ROOT/default@2019-02-03-16:57:45:/boot/modules/amdgpu_tonga_mec2_bin.koClearly this is not ideal. So, I did a fresh install and loaded from my config with the same result.
Thanks!
