Not 100% sure if I'm going to build 9.10 or 11.0, but if it's stable enough, I'll go for 11.0.
I'm looking for recommendations for USB drives to use as a mirrored boot drive,
and these are the choices that I'm looking at: (Canadian Prices from Local Supplier)
SanDisk Ultra Flair 32GB USB 3.0 Flash Drive (SDCZ73-032G-G46) $19.99
SanDisk Ultra Flair 64GB USB 3.0 Flash Drive (SDCZ73-064G-G46) $39.99
SanDisk Extreme 64GB Flash Drive USB 3.0 (SDCZ80-064G-C46) $49.99
SanDisk Extreme 32GB Flash Drive USB 3.0 (SDCZ80-032G-C46) $39.99
A pair of SDCZ73-032G-G46 with tax is about $45 vs $90 for a pair of the
SDCZ80-032G-C46. The Extreme is a lot higher performance than the Ultra
Flair, but I'm wondering is the higher performance worthwhile?
Should I consider a 64GB drive, or is the extra space a waste of money in this
application? I would hope
Are the USB drives accessed after initial boot or is the drive content cached to memory?
Other than configuration changes how often are the boot drives written?
Any comments/guidance is much appreciated.
