Boot drive error message???
John Farrar
The following is a clip of the error message report I get on what I believe is the boot drive. It is a SuperMicro Serial ATA "Dongle" type flashdrive. It appears that the media is failing, but I am not sure if this is just the natural aging of the flashdrive or indication that it should be replaced.
Thanks,
John Farrar
(ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 d8 2c f8 40 84 00 00 00 00 00
> (ada0:ahcich0:0:0:0): CAM status: Uncorrectable parity/CRC error
> (ada0:ahcich0:0:0:0): Retrying command
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 e0 60 82 40 85 00 00 00 00 00
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 40 ae e9 40 89 00 00 00 00 00
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 08 d1 0f 40 8a 00 00 00 00 00
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 88 cb 54 40 8a 00 00 00 00 00
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 38 24 a0 40 8a 00 00 00 00 00
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 30 c7 ce 40 85 00 00 00 00 00
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 40 50 a4 37 40 86 00 00 00 00 00
Sakuru
Please post the output of "smartctl -a /dev/ada0" in code tags.
m0nkey_
This is classic 'your boot drive is failing'. You will need to backup your config, replace the drive and re-install. You may want to consider getting two drives to replace it so you can have a mirror.
ethereal
or an ssd
