Please help, 7 Reported_Uncorrect Errors reported by smartctl !
vicmarto
Hello.
Just finished to upgrade my NAS with this second hand parts:
Supermicro X10SLM+-F
4x Hynix HMT41GU7AFR8A-PB ---> That successfully passed 3 consecutive memtest86 tests
And reused these parts (bought new):
6x Seagate ST4000DM004-2CV104
Intel i3-4130T CPU
Be Quiet! Straight Power 10 500W CM
One important thing, the SATA cables are new (and cheap).
Well, after 3 successfully memtest86 tests decided to do a pool scrub and get 23 CKSUM errors, but the scrub corrected the problem:
pool: zpool
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub repaired 368K in 0 days 08:32:14 with 0 errors on Thu Nov 1 07:03:01 2018
NAME STATE READ WRITE CKSUM
zpool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/e26154dd-3e66-11e8-b773-d05099c0a874.eli ONLINE 0 0 23
gptid/e475c2ec-3e66-11e8-b773-d05099c0a874.eli ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
gptid/ec709692-3e66-11e8-b773-d05099c0a874.eli ONLINE 0 0 0
gptid/ef9b0fdc-3e66-11e8-b773-d05099c0a874.eli ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
gptid/f5bde13d-3e66-11e8-b773-d05099c0a874.eli ONLINE 0 0 0
gptid/f7de159d-3e66-11e8-b773-d05099c0a874.eli ONLINE 0 0 0
errors: No known data errors
Well, then decided to stress a little the disks and system. So did a:
smartctl -t long /dev/ada0 and simultaneously a big and large rsync -c to the pool. Well... the result was a little catastrophic to /dev/ada0:
"Extended offline Interrupted (host reset)" !!!!:
smartctl -l selftest /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
# 1 Extended offline Interrupted (host reset) 00% 9543 -
# 2 Conveyance offline Completed without error 00% 9486 -
# 3 Short offline Completed without error 00% 9486 -
# 4 Short offline Completed without error 00% 9439 -
# 5 Short offline Completed without error 00% 9391 -
# 6 Short offline Completed without error 00% 9343 -
# 7 Short offline Completed without error 00% 9295 -
# 8 Extended offline Completed without error 00% 9250 -
# 9 Short offline Completed without error 00% 9199 -
#10 Short offline Completed without error 00% 9151 -
#11 Short offline Completed without error 00% 9103 -
#12 Short offline Completed without error 00% 9055 -
#13 Short offline Completed without error 00% 9007 -
#14 Short offline Completed without error 00% 8959 -
#15 Short offline Completed without error 00% 8916 -
#16 Short offline Completed without error 00% 8868 -
#17 Short offline Completed without error 00% 8805 -
#18 Short offline Completed without error 00% 8757 -
#19 Short offline Completed without error 00% 8709 -
#20 Short offline Completed without error 00% 8661 -
#21 Extended offline Completed without error 00% 8614 -
This "host reset" don't minds the NAS reseted, the uptime is ok.
FreeBSD ATA Status Errors:
Nov 3 22:57:57 nas ahcich0: Timeout on slot 11 port 0
Nov 3 22:57:57 nas ahcich0: is 00000000 cs 00000800 ss 00000000 rs 00000800 tfd c0 serr 00000000 cmd 0004cb17
Nov 3 22:57:57 nas ahcich0: Error while READ LOG EXT
Nov 3 22:57:57 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 ef 2b 40 a9 01 00 01 00 00
Nov 3 22:57:57 nas (ada0:ahcich0:0:0:0): CAM status: ATA Status Error
Nov 3 22:57:57 nas (ada0:ahcich0:0:0:0): ATA status: 00 ()
Nov 3 22:57:57 nas (ada0:ahcich0:0:0:0): RES: 00 00 00 00 00 00 00 00 00 00 00
Nov 3 22:57:57 nas (ada0:ahcich0:0:0:0): Retrying command
Nov 3 22:57:57 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f0 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): ATA status: 00 ()
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): RES: 00 00 00 00 00 00 00 00 00 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): Retrying command
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f1 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): CAM status: ATA Status Error
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f2 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f3 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f4 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f5 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f6 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f7 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f8 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f9 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 ef 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC )
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): RES: 41 40 e8 ef 2b 00 a9 01 00 00 01
Nov 3 22:58:46 nas swap_pager: indefinite wait buffer: bufobj: 0, blkno: 1054375, size: 8192
Nov 3 22:58:46 nas swap_pager: indefinite wait buffer: bufobj: 0, blkno: 1078257, size: 4096
Nov 3 22:58:46 nas swap_pager: indefinite wait buffer: bufobj: 0, blkno: 1083650, size: 20480
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): Error 5, Retries exhausted
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 e0 f0 2b 40 a9 01 00 01 00 00
Nov 3 22:58:46 nas (ada0:ahcich0:0:0:0): RES: 41 40 e0 f0 2b 00 a9 01 00 00 01
Nov 3 22:58:46 nas ahcich0: Timeout on slot 23 port 0
Nov 3 22:58:46 nas ahcich0: is 00000000 cs 00800000 ss 00000000 rs 00800000 tfd c0 serr 00000000 cmd 0004d717
Nov 3 22:58:46 nas ahcich0: Error while READ LOG EXT
Nov 3 22:58:46 nas GEOM_ELI: g_eli_read_done() failed (error=5) gptid/e26154dd-3e66-11e8-b773-d05099c0a874.eli[READ(offset=3650048933888, length=262144)]
Nov 3 22:58:46 nas ZFS: vdev state changed, pool_guid=11965637741579496532 vdev_guid=12741579445138213104
7 Reported_Uncorrect:
# smartctl -a -q noserial /dev/ada0
Model Family: Seagate Barracuda 3.5
Device Model: ST4000DM004-2CV104
Firmware Version: 0001
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5425 rpm
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Nov 4 21:53:28 2018 JST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 0) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 490) minutes.
Conveyance self-test routine
SCT capabilities: (0x30a5) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 084 064 006 Pre-fail Always - 228832872
3 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 204
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 089 060 045 Pre-fail Always - 829806015
9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 9566 (192 112 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 102
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 093 093 000 Old_age Always - 7
188 Command_Timeout 0x0032 100 098 000 Old_age Always - 0 0 2
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 057 040 Old_age Always - 34 (Min/Max 20/38)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 245
193 Load_Cycle_Count 0x0032 099 099 000 Old_age Always - 2857
194 Temperature_Celsius 0x0022 034 043 000 Old_age Always - 34 (0 14 0 0 0)
195 Hardware_ECC_Recovered 0x001a 084 064 000 Old_age Always - 228832872
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 8903h+18m+26.588s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 77088776992
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 203278125912
SMART Error Log Version: 1
ATA Error Count: 7 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 7 occurred at disk power-on lifetime: 9543 hours (397 days + 15 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 00 ff ff ff 4f 00 3d+03:03:15.826 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 3d+03:03:15.825 READ FPDMA QUEUED
Error 6 occurred at disk power-on lifetime: 9543 hours (397 days + 15 hours)
60 00 00 ff ff ff 4f 00 3d+03:03:10.935 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 3d+03:03:10.934 READ FPDMA QUEUED
Error 5 occurred at disk power-on lifetime: 9543 hours (397 days + 15 hours)
60 00 00 ff ff ff 4f 00 3d+03:03:06.751 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 3d+03:03:06.750 READ FPDMA QUEUED
Error 4 occurred at disk power-on lifetime: 9543 hours (397 days + 15 hours)
60 00 00 ff ff ff 4f 00 3d+03:03:03.062 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 3d+03:03:03.061 READ FPDMA QUEUED
Error 3 occurred at disk power-on lifetime: 9543 hours (397 days + 15 hours)
60 00 00 ff ff ff 4f 00 3d+03:02:59.033 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 3d+03:02:59.032 READ FPDMA QUEUED
# 1 Conveyance offline Completed without error 00% 9566 -
# 2 Short offline Completed without error 00% 9566 -
# 3 Extended offline Interrupted (host reset) 00% 9543 -
# 4 Conveyance offline Completed without error 00% 9486 -
# 5 Short offline Completed without error 00% 9486 -
# 6 Short offline Completed without error 00% 9439 -
# 7 Short offline Completed without error 00% 9391 -
# 8 Short offline Completed without error 00% 9343 -
# 9 Short offline Completed without error 00% 9295 -
#10 Extended offline Completed without error 00% 9250 -
#11 Short offline Completed without error 00% 9199 -
#12 Short offline Completed without error 00% 9151 -
#13 Short offline Completed without error 00% 9103 -
#14 Short offline Completed without error 00% 9055 -
#15 Short offline Completed without error 00% 9007 -
#16 Short offline Completed without error 00% 8959 -
#17 Short offline Completed without error 00% 8916 -
#18 Short offline Completed without error 00% 8868 -
#19 Short offline Completed without error 00% 8805 -
#20 Short offline Completed without error 00% 8757 -
#21 Short offline Completed without error 00% 8709 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I'm going to shutdown the NAS, check the /dev/ada0 cable and do a long smartctl test to all 6 disks. Please, need help, what more should I do now?
Run the extended SMART test but this is a error that I've only seen on Seagate drives:
UNC sector but at a bogus LBA address, it's usually a disk problem, but it can be intermittent, i.e., it might pass the extended SMART test, in that case keep an eye on it but I would replace if more error on the same disk.
garm
Run long smart tests, personally I would just replace the drive.
vicmarto
Thanks my friends,
Now it's running long tests in all 6 disks. Will report as soon as finish.
vicmarto
Well, the long test are ok in all 6 disks, including the problematic one... Is there anything else I can do besides replace it?
