Boot Drive Capacity Warning
Kortex
The system is throwing a warning for the boot drive being 82% full. Interestingly:
Why would 11.1-U7 be taking up 12 gigs? Thank you!!
Chris Moore
I wonder if you don't have some other snapshots in your boot pool that are taking up this space.
Would you share the output of zfs list -t snapshot?
Here is the similar listing from my system:
freenas-boot                                                      11.9G  24.2G    31K  none
freenas-boot/.system                                               231M  24.2G  3.75M  legacy
freenas-boot/.system/configs-7f5b34811f49423b82ac573d9dd30fdd     78.0M  24.2G  78.0M  legacy
freenas-boot/.system/cores                                        74.8M  24.2G  74.8M  legacy
freenas-boot/.system/rrd-7f5b34811f49423b82ac573d9dd30fdd         73.1M  24.2G  73.1M  legacy
freenas-boot/.system/samba4                                        206K  24.2G   206K  legacy
freenas-boot/.system/syslog-7f5b34811f49423b82ac573d9dd30fdd      1.58M  24.2G  1.58M  legacy
freenas-boot/ROOT                                                 11.6G  24.2G    25K  none
freenas-boot/ROOT/11.0-U3                                          164K  24.2G   726M  /
freenas-boot/ROOT/11.0-U4                                          186K  24.2G   728M  /
freenas-boot/ROOT/11.1-RELEASE                                     397K  24.2G   826M  /
freenas-boot/ROOT/11.1-U1                                          207K  24.2G   826M  /
freenas-boot/ROOT/11.1-U2                                          205K  24.2G   833M  /
freenas-boot/ROOT/11.1-U4                                          146K  24.2G   837M  /
freenas-boot/ROOT/11.1-U5                                          224K  24.2G   849M  /
freenas-boot/ROOT/11.1-U6                                          157K  24.2G   849M  /
freenas-boot/ROOT/11.1-U6.3                                        208K  24.2G   792M  /
freenas-boot/ROOT/11.1-U7                                         8.51G  24.2G   752M  /
freenas-boot/ROOT/9.10.1-U1                                         43K  24.2G   638M  /
freenas-boot/ROOT/9.10.1-U2                                         53K  24.2G   636M  /
freenas-boot/ROOT/9.10.1-U3                                       15.9M  24.2G   637M  /
freenas-boot/ROOT/9.10.1-U4                                       15.0M  24.2G   636M  /
freenas-boot/ROOT/9.10.2-U2                                       16.2M  24.2G   653M  /
freenas-boot/ROOT/9.10.2-U3                                         63K  24.2G   653M  /
freenas-boot/ROOT/9.10.2-U5                                       3.02G  24.2G   655M  /
freenas-boot/ROOT/default-20170722-020143                          186K  24.2G   737M  legacy
freenas-boot/grub                                                 20.1M  24.2G  6.95M  legacy
As you can see, the 11.1-U7 part is only 8.51GB.
It is also possible (I have seen it before) that you might have put some data in your /root or someplace else that is being stored on the boot pool instead of in the data pool.
Kortex
Thanks for replying a while back. My wife delivered a divorce so I was gone for a while. Anyway:
freenas-boot/ROOT/11.1-U7@2017-06-18-21:13:20          4.54M      -   980M  -
freenas-boot/ROOT/11.1-U7@2017-07-05-13:07:46          4.55M      -   980M  -
freenas-boot/ROOT/11.1-U7@2017-07-24-01:19:47           978M      -   979M  -
freenas-boot/ROOT/11.1-U7@2017-09-09-23:53:23           981M      -   982M  -
freenas-boot/ROOT/11.1-U7@2017-10-01-23:51:55           969M      -   970M  -
freenas-boot/ROOT/11.1-U7@2017-12-16-18:57:11           971M      -   973M  -
freenas-boot/ROOT/11.1-U7@2018-02-21-14:55:32          1.08G      -  1.08G  -
freenas-boot/ROOT/11.1-U7@2018-03-31-15:44:52          1.09G      -  1.09G  -
freenas-boot/ROOT/11.1-U7@2018-05-31-22:43:22          1.09G      -  1.09G  -
freenas-boot/ROOT/11.1-U7@2018-09-05-14:30:10          1.09G      -  1.10G  -
freenas-boot/ROOT/11.1-U7@2019-01-19-02:57:02          1.09G      -  1.10G  -
freenas-boot/ROOT/11.1-U7@2019-01-27-15:21:35          1.04G      -  1.04G  -
jvol/jails/.warden-template-pluginjail-11.0-x64@clean   151K      -   604M  -
Kortex
It looks like data was written between 07-05-2017 and 07-24-2017 and then included in the snapshot. What do I do about that?
Kortex
Does anyone know what to do here? The setup doesn't make sense and I'm lost.
What's the output of zfs list -r -o space freenas-boot?
Kortex
Output:
NAME                               AVAIL   USED  USEDSNAP  USEDDS  USEDREFRESERV  USEDCHILD
freenas-boot                       2.11G  12.3G         0    176K              0      12.3G
freenas-boot/ROOT                  2.11G  12.3G         0    136K              0      12.3G
freenas-boot/ROOT/11.0-U1          2.11G   240K         0    240K              0          0
freenas-boot/ROOT/11.0-U2          2.11G   352K         0    352K              0          0
freenas-boot/ROOT/11.0-U3          2.11G   256K         0    256K              0          0
freenas-boot/ROOT/11.0-U4          2.11G   240K         0    240K              0          0
freenas-boot/ROOT/11.1-RELEASE     2.11G   372K         0    372K              0          0
freenas-boot/ROOT/11.1-U2          2.11G   380K         0    380K              0          0
freenas-boot/ROOT/11.1-U4          2.11G   504K         0    504K              0          0
freenas-boot/ROOT/11.1-U5          2.11G   520K         0    520K              0          0
freenas-boot/ROOT/11.1-U6          2.11G   396K         0    396K              0          0
freenas-boot/ROOT/11.1-U6.3        2.11G   380K         0    380K              0          0
freenas-boot/ROOT/11.1-U7          2.11G  12.2G     11.2G   1023M              0          0
freenas-boot/ROOT/Initial-Install  2.11G     8K         0      8K              0          0
freenas-boot/ROOT/default          2.11G   232K         0    232K              0          0
freenas-boot/grub                  2.11G  7.94M         0   7.94M              0          0
Kortex
So, I deleted some of the older installs and this is the new output. I still don't understand what the issue is.
freenas-boot                       4.98G  9.44G         0    176K              0      9.43G
freenas-boot/ROOT                  4.98G  9.39G         0    136K              0      9.39G
freenas-boot/ROOT/11.0-U4          4.98G   240K         0    240K              0          0
freenas-boot/ROOT/11.1-RELEASE     4.98G   372K         0    372K              0          0
freenas-boot/ROOT/11.1-U2          4.98G   380K         0    380K              0          0
freenas-boot/ROOT/11.1-U4          4.98G   504K         0    504K              0          0
freenas-boot/ROOT/11.1-U5          4.98G   520K         0    520K              0          0
freenas-boot/ROOT/11.1-U6          4.98G   396K         0    396K              0          0
freenas-boot/ROOT/11.1-U6.3        4.98G   380K         0    380K              0          0
freenas-boot/ROOT/11.1-U7          4.98G  9.39G     8.39G   1023M              0          0
freenas-boot/ROOT/Initial-Install  4.98G     8K         0      8K              0          0
freenas-boot/ROOT/default          4.98G   232K         0    232K              0          0
freenas-boot/grub                  4.98G  7.94M         0   7.94M              0          0
pro lamer
Do you still get the same message? Now you have roughly 2GB free more than before...
Sent from my phone
Kortex
I'm not getting the messages now, no. Are the others safe to delete though? 11.0-U4, 11.1-RELEASE, 11.1-U2... I just don't delete 11.1-U7 I guess?
