Heyho small problem here and looking for advice^^.
Here the System Specs:
Boot device: Transcend JetFlash 8 GB Flashdrive
Mainboard: Asrock C2750D4I
RAM: 16 GB Kingston ValueRAM DDR3-1333 ECC DIMM
PSU: 360 Watt Seasonic G Serie
Storage: 3x 3TB WD Red in RaidZ-1
Now to my problem. The USB Stick was throwing some (around 6) Checksum errors out in the last month but today its at 51. When I first got the message about them I was thinking its not a big deal because I want to swap out the boot drive with 2 small sized SSDs in the summer but now I am a bit worried^^.
Should I simply reinstall freenas on the same USB Stick until I can get the SSDs? Can the problem cause data corruption on my data zpool? If not would I be too crazy to let it run like this until I get the SSDs?
Here is the zpool status -v output:
Current build I am on is: FreeNAS-9.3-STABLE-201502271818.
pool: freenas-boot
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0h36m with 13 errors on Mon May 25 21:19:30 2015
NAME STATE READ WRITE CKSUM
freenas-boot DEGRADED 0 0 25
da0p2 DEGRADED 0 0 51 too many errors
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818@2015-03-06-14:45:33:/usr/local/lib/db48/libdb_cxx-4.8.a
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201504100216@2015-04-13-17:52:12:/usr/bin/nslookup
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201504100216@2015-04-13-17:52:12:/usr/bin/nsupdate
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201504100216@2015-04-13-17:52:12:/usr/local/libexec/git-core/git-fast-import
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201504100216@2015-04-13-17:52:12:/usr/local/libexec/git-core/git-http-backend
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201504100216@2015-04-13-17:52:12:/usr/local/libexec/git-core/git-http-fetch
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818@2015-01-24-21:59:19:/boot/kernel/kernel Current build I am on is: FreeNAS-9.3-STABLE-201502271818.
