Bitwarden and TrueNAS Scale login
mrbrdo
I am surprised nobody raised this yet, but Bitwarden will not autocomplete my username on the login page on page load. It will autocomplete it if I do it manually after the page is loaded, but on page load, only the password is filled. It seems like the login page does some delayed loading of the login form and I suspect this is why the username is not filled correctly. Since Bitwarden works fine for hundreds of other pages I use, I think this is an issue with TrueNAS doing the login form in an unconventional way.
What makes it even worse is that TrueNAS Scale is pretty bad at remembering I am logged in and will ask for login quite often, which is another issue in itself.
It would be great if this could be fixed. If someone has a workaround I would be happy to hear it.
If you want the devs to look at it, file a ticket--use the "Report a Bug" link at the top of the page.
