Bind Required with Virtual Machines
doughyboy
I'm running SCALE (the latest nightly) and I've had this issue for the last few nightlies where, when I go to create a virtual machine, it tells me that "Bind is required," but then gives me nothing to bind to.
I have unused network interfaces so I don't think that is the issue, I've been trying to deploy a VM for the past few days and haven't been able to do so.
I'm wondering if this is a bug within SCALE itself, or if this is just user error?
Any help would be appreciated, thank you!
morganL
Captain Morgan
Administrator
Could you verify if the same issue is in the 21.02 version? If it is please "report a bug".
The Nightly's are a development branch that don't have a full QA cycle. Things may have been broken.
beagle
I had this problem as well with March nightlies. Yesterday I rolled back to a 25th Feb installation and it is working again.
You may need to wait a few days until a new nightly corrects the problem.
ornias
Though I do not think this one is reported yet, so OP might want to file a jira report none-the-less.
because often: No-Jira-No-Fix
oumpa31
Glad i came across this. I just switched to the nightly to see if the nvidia transcoding fix was uploaded yet and went to make a VM to test for my camera system that only has windows software and couldn't create it.
stavros-k
While the ticket seems resolved, i'm still having the same problem. I have updated to the latest nightly. Is there any chance it didn't get into the latest build yet?
Should i open new ticket or is it going to be on 21.04?
