Bigger ImagePull Failing through charts
mnbk91
I'm a noob here and i just need clarification on something
Recently i noticed in my truenas scale install that some of the larger apps when i try to install them either through truecharts or official catalog (ex. Nextcloud, collabora etc..) keep failing at deployment stuck in the step
collabora
Failed to pull image "tccr.io/truecharts/collabora:v22.05.4.1.1@sha256:4b7c9b3583309d4717fb64fa1e5115695abd7e98db4bc02dff0a24cf3ac74b6c": rpc error: code = Unknown desc = context canceled
nextcloud
Failed to pull image "tccr.io/truecharts/nextcloud-fpm:v24.0.3@sha256:a307c7d49d5c7c691916f2e6bdbb10bc698bbd58498de12c4db992c4755a7018": rpc error: code = Unknown desc = context canceled
Initially i thought this was DNS issue and tried changing my dns to various providers, and I was pulling my hair trying do a lot of things from various forums/discord chats but none of it seemed to work all my configuration for the charts were correct, my dns was correct and my permissions were correct but yet bigger images seem to keep failing in the image pull stage.
After two weeks i was able to solve this by pulling the image manually using a ssh connection to my truenas scale with the command suggested by another user in the forums @aekt
docker image pull
after pulling the image manually and then trying to install it using truecharts catalog works, no issues. clean install
Note: pulling the image manually took nearly 10-15mins each time, download was completed immediately. But to extract the various parts it took some time
so my question here is why when I pull it using truecharts catalog the automatic pull generates an error for this and is there a way to solve this and let the process know that the image is being extracted.
My truenas scale configuration is as follows
OS Version:TrueNAS-SCALE-22.02.2.1
Product:ProLiant DL380p Gen8
Model:Intel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz
Memory:20 GiB
The os is running off a 32gb pendrive
I have two pools
Image pool - 2*128gb Nvme ssd connected through PCIe (used for app storage) (Mirrored)
Tank - 4*4tb HDD segate (raidZ1) (other storage)
Would love to get an idea of why this happens to fix the issue in the future, if any other details are required to fill in the gaps please do let me know.
Thanks in advance
morganL
Captain Morgan
Administrator
collabora
nextcloud
docker image pull
Memory:20 GiB
I have two pools
Thanks in advance
Thanks for documenting this well... could you "report a bug" and the engineering team can look at it.
Perhaps there is a timeout on the imagepull... what is your network speed? Document what you can and share with the group the bug report.
waqarahmed
@mnbk91 please create a ticket at https://ixsystems.atlassian.net/ and kindly make sure to attach a debug of your system and also the files generated by the following commands:
1. journalctl --no-pager -u k3s > k3s-scale.log
2. journalctl --no-pager -u docker > docker-scale.log
Btw if you are able to reproduce this, please reproduce and then attach a debug and run the above commands so we are sure this is captured in the logs and not cycled out. Thanks!
mnbk91
@waqarahmed & @morganL Created a ticket with the above mentioned data. I was able to re-create the issue with both official catalog (Collabora) and Truecharts (Outline) If any other info is required please do let me know.
My internet speed is 300Mbps
morganL
Captain Morgan
Administrator
Thanks.. that's NAS-117452
@wsoteros Notice that the Jira inks now should show the generic "log In" screen rather than the specific Bug ID. Can that be fixed?
morganL
Captain Morgan
Administrator
Also that ticket is not public (even for registered users)
Apologies.. there is an issue protecting users debug and log files. If we have them on the ticket, the ticket is private. We are developing workarounds.
stavros-k
Np, thanks for letting us know that you are working on it!
Flynn84
Having the same problem on a slow internet connection when pulling an image. Manually pulling the failed image via docker pull solves the problem immediately and causes the app to deploy.
Failed to pull image "tccr.io/truecharts/jellyfin:10.8.9@sha256:32efce54017dcefcd437dc179baabb0ed79ad44298b9d0850388bd69f8e9eac5": rpc error: code = Unknown desc = context deadline exceeded
@morganL Can you guys confirm that you are putting some prio on fixing this? It's been over half a year now and this is still a problem.
Samuel Tai
@Flynn84, TrueNAS is not responsible for TrueCharts. Please consult TrueCharts for issues with TrueCharts apps.
morganL
Captain Morgan
Administrator
The problem may be caused by several issues:
1) Your network bandwidth
2) Bandwidth from TrueCharts repository
3) Time-out that is too aggressive
Given the docker pull is fast.. its probably not 1)
It would be good to get some technical data.
Can you measure the rate of download when you are pulling?
Can you compare this with a docker pull?
What is the size of the jellyfin image being pulled?
When is it timeing-out?
Flynn84
Pretty sure this is not a TrueCharts issue but I may be wrong.
I read that this is a known k3s issue though that primarily occurs on slow connections here. I assumed this was related to the error that the op was getting but maybe it is a different issue entirely.
I am getting the full connection speed of my line on both. The pull through app deployment reliably errors out after about two minutes. I've done some more reading about the k3s issue and a timeout after two minutes is described there also. Docker pull takes about seven minutes give or take with no errors. I can post more details but am about to head to bed so that would be tomorrow.
morganL
Captain Morgan
Administrator
Thanks... so if you can get the size of the pull and the expected speed, we can see if this is a tunable that might be needed.
It's not something I've seen commonly recently... are you on 22.12.2?
Flynn84
Yes, 22.12.2. Also encountered the Reporting tab showing null on all values. Changing BIOS time unfortunately didn't fix that. Kinda frustrating.
Flynn84
Size of the pull was about 300MB I think and expected speed on the dashboard matched speed of my internet connection.
