Gruselbauer
- Oct 11, 2016
Hello everyone,
I've set up a FreeNAS install for a business venture with my best friend. Mostly needed was reliable, enterprise grade storage on the cheap, and for that I'm just hella thankful to everyone involved in FreeNAS. A 12tb NAS with the option for two drives failing simultaneously at below 600eur is still blowing my mind.
Basically, I have the exact problem somebody detailed in this thread:
https://linustechtips.com/main/topic/948913-how-to-vnc-connect-to-a-freenas-vm/
Hardware is as follows:
2x Intel Xeon E5506
72gb DDR3 ECC Memory
7x 2tb spinning rust (different brands and lines) in RAIDZ-2
2x 120gb SSD mirrored as system disks
No name server board off Ebay
I know I am limited to one vCPU by the physical CPU, also the FreeNAS web GUI tells me that. Everything else works flawlessly, from network shares to jails and plugins. Trying to create a Windows or Linux VM however just does not work no matter what option I change. I've toyed with different NIC devices, changed the UEFI setting to UEFI_CSM, allocated more or less memory and tried my luck with an array of different ISOs from Ubuntu Server to Windows 10 in both 32 and 64 bit flavors.
When I uncheck "Wait to Boot" in the VNC device options, the VMs won't start at all and give me this error:
When I check that box and try to connect via the web interface, the popup for http://myinternalip:port/vnc.html?autoconnect=1 gives me error number 1006 and then the VM stops running. Also note that the port number it tries to access is wrong, and always by exactly 100. If I have VNC configured to run on 13199, the web interface will try to open 13099 and so on, reliably and no matter. If I try to connect with a Linux/macOS/Windows VNC client, I get "unexpected connection error" replies, and after the first attempt the VM will also stop running.
I realize bhyve is a rather young project and I'm running Xeons from 2009, so I'm pretty much prepared to hear that this is a hardware incompatibility. Still, any help would be immensely appreciated and maybe I can be of use in mitigating this problem? Not much data on the NAS so far and I'm down to reinstall or try a more recent build.
Thanks a lot for any replies!
2x Intel Xeon E5506
Error: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1109, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1049, in _call return await methodobj(*args) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 1132, in start await self._manager.start(vm) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 61, in start list(done)[0].result() File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 315, in run raise CallError(f'VM {self.vm["name"]} failed to start: {output}') middlewared.service_exception.CallError: [EFAULT] VM blaaaa failed to start: 04/12/2018 19:17:10 Listening for VNC connections on TCP port 5857 04/12/2018 19:17:10 Listening for VNC connections on TCP6 port 5857 ROM boot failed: unrestricted guest capability not available fbuf frame buffer base: 0x942e00000 [sz 16777216]
