I would like to replace a 2 disk mirror pool (harddisk to ssd). problem is i haven't got any more available extension slot so the only way to add a disk is by removing at list one of the old ones. the net is quite slow there so it would really be of great help if I could import disk or something. currently there is a cache disk there which I don't need. so maybe that could be of help?
thanks ahead.
edit:
cache disk is very small and also ssd are about half the size of the original disks
thanks ahead.
edit:
