So I tired mounting the timecapsule data as an CIFS share to freenas then copy over to a dataset. It is really slow. I know that its slow because Samba is single threaded. Does timecapsule run an NFS server? Or can I mount an AFP share to freenas?
I'm not sure on your question, but can I make a suggestion? Set up an AFP share on your freenas box and do time machine directly to it. Your time capsule is susceptible to bit rot. Your freenas box is not.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
