I'm building a storage server for 12x 2tb sas hard drives. Storage space is not the issue (my application will likely never exceed 1tb), I went with 2tb since I found some cheap.
I need speed. Faster the better. I have a dedicated backup server already, and I'm looking to move the programs used on the individual servers to all launch from one storage server. I dont want to have the system fail from a single drive failure, but i have no issue with a 2 drive failure causing issues.
Looking online it seems a raid 10 might be my best bet, since it can withstand a 1 drive failure but not two, but perhaps there is another faster option?
Another question i have is what hardware would be good for speed? I plan to use 64gb ram (probably ddr2). I assume that to be enoughph since this won't be doing anything fancy, no applications or plugins installed, dedicated server.
Looking online the hp p410 raid card seems to be cheep (obviously using it as a "dumb" controller, letting truenas do the raid), but not the fastest. Would using 2 of these be a bad idea, or would my system bottleneck elsewhere? I'm thinking I might Team two sfp 10gb connections together to the switch.
Any input is appreciated, I'll admit I'm a storage noob. Thanks.
